I have a MadDog 3.5" Aluminum Anodized HD
  • 822 Answers
Yes..your pc wont be able to read it.............
cheers
Posted on Mar 24, 2011
Repair for Innova GT 3 led, 3 AA battery flashlight.
Before doing serious damage, check for a poor ground to the case. I have worked on a couple of these and some of the manufacturers seem to believe a solder connection to an anodized aluminum case is going to work. Use a tool with a sharp point to scratch through the anodized layer to expose a clean metal ground. You may have to repeat this from time to time as the light fails.
Aug 26, 2016 | Camping, Backpacking & Hiking
What external drive enclosure would support a seagate 4200.2 hard drive
Hi Larry
There are generally 2 types (sizes) of hard drive. 2.5 Inch & 3.5 inch. Any 3.5" HD enclosure these days should handle either size.
The preferred current connector on a HD is SATA (Serial ATA)This small connector on the HD is universal so it's easy to connect a drive. 3.5" HD is preferable for backups & archive as it is faster, more reliable and less prone to bumps. They run on 12v&5v
The Pocket type 2.5" run on 5v and are not as fast or secure.
My preferred Enclosure that I use is more of a Universal Dock.
Either drive can be plugged in at any time. This is great for allowing the use of several drives for different purposes. Eg
A Movies Drive. A Backup Drive. A Music Drive or a Bootable External OS in case of problems. Buy USB3 Port Interface where possible or FireWire as the backup speed is Faster
Drives not in use get wrapped in antistatic bag or tinfoil & kept in secure location.
I use Carbon Copy Cloner to make a Bootable copy of OSX.
Great program... used it for years. Demo is free and fully usable.
Hope this helps
NewerTech Voyager S3
Mac Backup Software
NewerTech Voyager S3 Hard Drive Docking Solution USB 3 0
Dec 02, 2015 | Seagate Computers & Internet
Jumper settings to connect to mac
If the hdd is a 3 1/2" version you need a power supply to run it. The usb will only power a mini SATA 2 1/2 or smaller as the 3 1/2 needs 12volt supply as well.
Jul 02, 2017 | Western Digital Caviar WD1600BB 160 GB...
Transplanting Hard drive from Seagate Free Agent go flex to another enclosure. I believe the power supply is dead only one light comes on and it just beeps
Here's one case. They're not terribly scarce, but not found just everywhere, either.
http://www.amazon.com/Aluminum-External-Drive-Enclosure-Silver/dp/B000F3WB0Y
Jul 07, 2011 | Seagate Free Agent Go Small 12 GB USB...
This was bought from a friend who no longer has the manual and I am still not quite sure what it is or what it does.
This is a case for 3.5" HDD that make any 3.5" HDD become external Drive. Here's the product description from Amazon :
The CoolMax HD-360-U2 USB 2.0 3.5" External Hard Drive Enclosure is portable size and excellent quality. The 3.5-inch hard drive aluminum external enclosure is specially designed for high capacity hard drives. And its aluminum material design is great for heat dissipation, so you don't need to worry about your hard drive overheating anymore. The HD-360-U2 Series gives you the freedom to work anywhere, no matter if you're in the office, at home or on the plane. This portable 3.5" HDD external enclosure provides maximum durability, flexibility and portability with various interfaces. Once you download your information to the HD-360-U2 series, you can connect it to any system and gain access to your programs and data files anywhere. With built-in hot swap technology, you can connect and disconnect the drive any time.
Features
  • Supports high speed data transfer rates up to 480/400 Mbps
  • Fully compatible with 3.5" IDE 133 HDD
  • Soft-start for slow turn-on feature prevents high inrush currents when initially powering capacitate loads
  • Anti-shock design, protect the hard disk from damage when moving it
  • Insulating designed PCB
  • Aluminum case transmits the heat quickly
  • Powered by a DC 12V-2.0 A transformer
You can visit the website : http://www.coolmaxusa.com/extenclosure.asp?item=3.5 for more details
Feb 07, 2011 | Coolmax HD-360B-U2 USB 2.0 External Drive...
Can I use an all aluminum cookware pot to cook pork in the oven?
Yes! you can use aluminum cookware in your oven. If you are using an aluminum pot of best brand, it would be safe for you to use it. You can also use cookwares made up of various other materials.
I also use aluminum cookware which is GSI Outdoor Hard Anodized, as it is light weighted and made of high-quality aluminum. Apart from these features, some of its other features are, great versatility, safe dishwasher, produce tasty food, etc. You can get more detail by clicking here.
Sep 11, 2010 | Microwave Ovens
I've got nexstar lite external 2.5 hd enclosure with 160 gig hd inside but it would not work because I'm running win 7 so please show me how to fix it.regard paul
Windows 7 is not supported by the Nextstar Lite external 2.5 hd enclosure. It's a windows XP supported device.
There is no support on this product for Windows 7.
Jun 25, 2010 | Office Equipment & Supplies
Need pressure cooker manual
The pressure cooker is make by Denmark PC, you can download a manual from
http://www.tabletopsunltd.com/en/main.html#use and care?id=61&cl=CL1
It's either hard anodized or polished aluminum.
Please rate this solution. Thanks.
Jul 09, 2009 | Cook's Essentials Cooks Essentials Arome...
Maddog External Harddrive Enclosure not recognized by computer
I realize the above questions are almost a year old but someone may try to research this at a later time so I thought I'd throw in my two cents.I have the Maddog Multimedia USB2.0/eSATA external harddrive enclosure which I connected to my computer last night but could only get it to appear as a "USB device" to my computer (in control Panel-System-Device Manager). It would not appear under Computer management so I could not force a drive letter on it and it would not appear in Windows Explorer. I removed the Seagate 1TB drive from the enclosure and connected it to my computer without an enclosure using an IDE/SATA interface I bought for another purpose. The drive worked fine. Today I took another look at the situation - I was going to try another drive in the MadDog enclosure to see if that worked but instead decided to reinstall the Seagate 1TB into the enclosure and try again. Same result until...I started reading through the comments above which forced me to look closer at the back of the device. That's when I remembered the device has a physical switch in the back for eSATA vs USB. I hadn't used this device in many months and my eSATA card has never worked on external drives so I forgot about it. sure enough I powered down the drive, flipped the switch to USB an powered up again. Problem solved. I am not new to this stuff but even experienced users can make a silly mistake. I only hope your issues are as easily solved.
Jan 18, 2009 | Computers & Internet
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
