Question about Koss KS3102 System
I am having problems reading dvd's, I clean them first, what is the best way of cleaning the read heads?
    Brigadier General:
  • 8,546 Answers
Don't. Prevention is better. Smoke and dust free environment. DVD's aren't LP's. There should be no ritual cleaning and fawning over them without cause. Avoid touching the playback surface and you shouldn't have to clean them other than to blow dust off.
Lots of good reading on optical discs.
http://www.repairfaq.org/sam/cdfaq.htm
Posted on Mar 25, 2011
I have an advent DV1418A and my built in dvd player wont work when i put a CLEAN WORKING disc in it says loading then it says "no disc" please help!
The READ head is dirty or damaged...very difficult to get to the back of TV to disassemble DVD player.. clean read (light diode) head with light cleaning fulid or don't take apart & use official cleaning DVD disc. Look on web site for CD\dvd cleaning disc.It looks like a CD but has 'fuzz' or a very thin " rug" on 'read' side of disc.
Aug 08, 2011 | Recoton Advent Advent DV1418A 14 in....
My dvd cant read dvd but can read cd
Your laser head needs eighter cleaning or replacement.
Use a cleaning CD with solution to clean your Laser head.
if problem still exists you have to do a better cleaning by opening the DVD ram and use ear buttonetes with alcohol (a little alcohol dont flood the buttonete).
If still exist you have to replace the laser head, mostly is more expensive than buing a new DVD.
Jul 29, 2011 | Computers & Internet
Player will not load dvd. I have cleaned everything, recharged, rested It just keeps loading on and on without connecting. Help.
This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
Jul 16, 2011 | Mintek DVD-1810 Portable DVD Player \
Dvd player won't play disc
The DVD read head may need to be cleaned. Sometimes perfectly OK drives also fail to read certain discs. If the problem is persistent, i.e. the notebook won't read any discs, then clean the head (with a head cleaner) and try again. If it starts working, fine.. If not, then you may have to replace the DVD drive. If the problem is only related to playing one particular DVD, then its the DVD that is faulty.
Hope this helps.
May 25, 2011 | Toshiba Satellite P505D-S8935 Notebook
I have a panasonic RV26 DVD player. After inserting DVD it goes to the reading mode (normal) but it stays on the reading mode for awhile then code H02 shows and then stops and and will not accept any other...
The Optical head or the mother board is defective. The data is not received and so the Mp is not able to read or process.
hence if have cleaned the optical head lens, and there is no reading try to put in a audio cd to test. If the cd is read the head must be Ok and the DVD processing must be faulty possible board issue but if there is no reading then the optica head is faulty
Aug 30, 2010 | Televison & Video
Reads disc not read or scan
You might have problem with read/write head with ur DVD Player. You can clean the head with a soft piece of clothe. It not post tell me agian.
Jun 25, 2009 | Televison & Video
Rca drc628 portable dvd not reading disc
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD lens cleaning CD.If still the problem persists, contact near by service center for replacing the faulty Lens.
Mar 12, 2009 | RCA DRC629N Portable DVD Player
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Sep 22, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
This is the most common problem, in most cases the burner must be replaced.
May 03, 2017 | Panasonic DMR-E80H DVD Recorder
Won't read dvd's
hi try first to clean up your laser sense with a clean up CD, after if your problem is still there, you have to go to specialist cause your laser sense is defficient, and used and have to be replaced, maybe the best thing to do is to buy a new DVD player.
you have to know that a laser sense has a limited life and it's normal to change it after aproximatly 2000 hours.
I hope this helps
Please rate accordingly
Thank You
sserpentio
May 11, 2008 | Panasonic DMR-E80H DVD Recorder
Koss KS3102 System Logo
43 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
