Question about Home
I need to increase the amount of water in tank to work well
  • 43,501 Answers
Are you talking about your well tank???
Why do you think that it is not working right???
Do you still have air in the tank??
If no air in the tank then the tank is bad...
here is a tip that I wrote about how to make sure the tank air charge is correct..
Well Pump Problems The Water Well Tank
Feel free to comment back if I have misread your question or if you have more questions...
heatman101
Posted on Mar 24, 2011
How do you increase the water temp?
Hi Donna:
The temperature is pre-set and is intended to be not too hot to inadvertently burn someone. Increasing the setting can cause a real SAFETY HAZARD, especially if small children or seniors are involved.
With that in mind, there will be a panel that unscrews from the side of the heater. After removing it, lift the insulation back and a dial should be visible. There will be numbers, and a pointer with a screw slot in the centre. Turning the pointer to a higher number will increase the temperature.
If you are going to adjust it, only do so a very small amount at one time, until you reach the desired temperature.
Remember, increasing the temperature will not give you more hot water, it will only give you hotter water. If you need more hot water, consider getting a larger tank or an "on demand" gas fired unit.
STAY SAFE!
Jan 12, 2016 | Water Water Heaters
Needs two flushes to empty bowel
might be that the water level in the tank is to low. if both buttons release the same amount of water then you have to increase the water level in the tank by adjusting the height of the floater on the inlet valve. look inside the tank and there should be a WL mark meaning water level should be set to this level minimum.
Nov 30, 2013 | Pfister VTP-E70W Kamato One-Piece Dual...
I just installed a new perfects. The pool of water in the bottom of the bowl is small, how do i increase the pool of water in the bottom of the bowl.
The toilet you just installed is a 1.6 gallon flush water saver and will not have the same amount of water in it that your old 3.5 gallon toilet had. The water level may not be able to be raised as this is the nature of the beast.
If you can raise the level it will only be a little and will be done in the tank area by increasing the water level in the tank. If the water level in the tank is at the mark provided it a done deal.
The amount of water refilled into the bowl is done by the tube that runs from the fill valve into the overflow tube of the flush valve so if you put more water into the tank more water will be put into the bowl but the bowl will only hold as much water as the trap weir will let it hold (what the factory has sit it at and is not changeable
Mar 07, 2011 | Jacuzzi Bath Perfecta EZ33 959 White round...
Is there a way to adjust the amount of water in your toilet bowl in order to improve the flush?
There is only one way to do this and that is to increase the water level in the tank. To explain the flush valve in the tank fills both the tank and refills the bowl at the same time if the valve runs longer to fill the tank it will at the same time put more water into the bowl. Now having said that the bowl will only hold a set amount of water before it starts running out into the drain. If the tank water level is at the line marked in the tank it will most likely not do much good to raise the level beyond that point and if the toilet you have is a 1.6 gallon flush tank I am sorry but learn to live with it.
Feb 11, 2011 | Plumbing
How do you get more water to stay in the toilet once the toilet has been flushed
Hello. Increase the amount of water that stays in the tank and you will automatically increase the amount of water in the bowl. Joe.
4 thumbs up please.
Oct 12, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Our water heater runs out of hot water after a couple showers. Does it need to be replaced? Is there something on it that I can check? Does increasing the temperature setting help?
when was the last time that you have "opened the flush valve (faucet) at the bottom of the tank to clear out the sediment? if it has been more then 4 years then you will need to do this depending where you are located this should be done once a year just to keep the tank clean. attach your garden hose to the valve and run it over to the sink open the valve for a few moments to clear out the tanks bottom (HOT WATER ALERT!) after doing this and if you have seen dirt come out then your tank should be clear. check to see what the tempature is every 1/4 inch is 10-30* increase hope this helps
Jan 20, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Increase water in toilet tank-low flush Toto toilet
Yes adjust the float level to raise the amount of water in the tank, If you have a float that is a ball around the tank you will have to turn the water off and remove the hose from the tank and remove the nut then pull the water float device out and you will see a clap on the bottom of the float you will turn the float base so that it gets longer, increase it by two inchess so that you increase water flow. Reinstall into the tank hook it all back up and leave the lid off turn on the water and watch the water level rise be sure the float shuts the water off before it over flows, if it starts to over flow then fush it to bring the water down giving you enought time to shut off the water valve.
There is a problem adding low water systems to older septic systems. The septic pipe settles in the ground over time and may cause a ~~~ in the pipe thus causeing blockage. For future reference you can add a one gallon bottle of water in the tank like a milk jug or a used up bottle of puerified water that you have drank and this will decrease it by one gallon per flush. Hope this helps. If you need more asstance just posttothis reply!
Nov 11, 2009 | Toto Ms874114sg-12 Carlyle Toilet With...
Not enough water in the bowl
The fill valve probably has a float that surrounds the pole that extends from the bottom of the tank. The float usually has a metal rod that comes down with a clip to adjust the float. Move that clip up so that the float sits higher-this should add more water to the tank.
Jun 26, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Home Logo
20 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
