Question about Dryers
Hello My simpson Eziloader Dryer will not spin I replaced the drum belt but still not fixed, if I turn it manually and close the door really quicly it will start turning but then stops soon after. Please help Thank you
  • 822 Answers
Need the cap replacing,........... should ba a silver can shaped cap. sited next to the motor
. it will have 2 or 4 wires connected at the top......................
cheers
Posted on Mar 24, 2011
The drum on my dyrer quit turning
Possible problem may be broken belt or misaligned door switch. Try carefully holding the door switch closed to see if the dryer starts. If the dryer turns while manually pressing the door switch, but not when the door is closed, then the switch is misaligned. Make switch alignment to fix.
Jan 04, 2014 | Samsung DV448AG 27" 7.4 cu. ft. 11 Cycle...
Dryer drum needs several manual pushes to start
or just a bad belt cheap but labor intensive
http://www.youtube.com/watch?v=7OVBi0LcrzQ
Apr 29, 2013 | LG DLE2532W Electric Dryer
I have an eziloader 6kg dryer, the drum does not spin but the heater element turns on. How do I check if the belt has come off?
can you turn the drum reasonably easy whilst the machine is empty and off . If you can than the drum has no load and the belt is either broken or has come off the drive pulley or the drum . Disconect power cord from socket and remove back off machine ..You know should be able to access drive belt and either replace belt onto drum and drive motor or purchase and fit new belt . It is a good idea to replace a belt that has slipped off and is not broken - belts stretch and its likely to come off again . If this is one with a sealed back then turn it on side and remove base to reach belt .
Aug 13, 2011 | Dryers
Where does the spring belt tension go on my simpson ezi loader dryer??? I was replacing the drum belt and it flicked off and I didnt see from where. A picture would be good.
the motor is spring loaded - move lift motor towrards the cabinet lining to the right. Put band around drum and pully at rear of motor then allow motor to move back onto band to cause the tension
Feb 17, 2011 | Dryers
Simpson eziloader 5.5kg washing machine When i turn it on and select a program the machine clicks and the light flashes three times and then turns off the cycle (the cycle does not commence).
1.Turn off machine 2.unplug from power 3.leave unplugged for 5-10 mins 4.open door (if has water in drain via pump/lint filter (botton right flap). 5.empty contents(if wet turn drum by hand( may be unbalanced) close door) 6. turn on power 7. select colours 40 cycle 8. press start button 9.wait a moment ( chip reset ) 10.hopefully machine will fill with water and let complete cycle
Jan 11, 2011 | Washing Machines
Dryer turns on when door is closed, heats up, no lint blockage, heats up, blower exhaust spins, belt intact, drum can be moved by hand. Drum won't spin when it's suppose to when you close the door, even if...
Hello- A little odd. It sounds to me like the belt is slipping. Sometimes they get stretched out enough that there is not enough pressure on the idler pulley for it to make good contact with the motor pulley. The Idler pulley may be broken as well or the belt has slipped off of it. Another possibility is that the belt has slipped off the motor pulley and is not being driven by the motor. You, or someone, really need to open it and see how the components look when it is on, if possible.
Sep 24, 2010 | Dryers
I have a simpson eziloader dryer modal 39S500 the belt broke. i need a diagram on how to replace it. I also have to replace the bearing.
Hi I have a simpson eziloader 5kg Model: 39S500. I've just replaced the drum and put it all together but I have a spring that I'm not sure where abouts it goes can anyone help thank u
Mar 15, 2010 | Dryers
How to turn on the simpson eziloader dryer
The timer is the "on" switch.
Things that can stop it starting.
Door switch- is the depresser pin contacting.
Broken main belt.
Faulty - motor- timer- door switch- belt switch ( if fitted) wireing.
Aug 29, 2009 | Dryers
Dryer will not spin
are you sure the drum belt isn't broken,the whirring noise your hearing sounds to me like the motor is turning
Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
918 people viewed this question
Top Dryers Experts
