Question about Panasonic Televison & Video
I have a Viera 42 inch plasma tv (model #THP42PZ700) that's 3 yrs old. Last night a 1 inch wide by 8 inch long black vertical line appeared on the left hand side of the screen. Any ideas on what the problem is?
  • bondo408 Mar 25, 2011
    Wow! Who would have thought a $3500 TV from the highly rated Panasonic brand would only last 3 years. We probably watched it less than 1 hr/day. It was first repaired within 3 months of being bought and I guess that should have been a clue. When I called Panasonic about this problem the first question was "Did you buy the extended warranty?" Guess we should have done that, too. Panasonic also said they have less than a 1% repair rate - the best in the industry. My goodness how bad are the other brands if Panasonic is so good? Well, we'll pay the $65 for the repairman to confirm your diagnosis and never buy Panasonic again!
  • 643 Answers
The problem is the panel is going bad. usually not economical to repair. repair usually runs as much as a new one.
Posted on Mar 24, 2011
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
We had a vertical line about 2 inches wide and going from top to bottom on our 42 inch viera that was a light green-barely interfering with picture. Now that area has gone black while the rest of the tv...
It is either the plasma panel itself or a connection problem, either way it will need to get serviced. Suggest you find receipt and phone Panasonic.
Cheers.
Sep 25, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Vertical black lines appear intermitently
Does the line appear on just one input(cable,hdmi,video1,video2,ect) or on all of them? The reason why I ask is it may be just an issue with one input setting on the television and you may be able to use a different input for a temporary fix of the problem. Plasma telivisions run very hot and it may be overheating. Try using a small mountable fan above the TV pointed into the back heat vents and see if keeping it cooler keeps the issue from happening. These TVs are repairable but usually cost more to repair than what it is worth due to plasma TVs are very in-expensive now.
Sep 04, 2009 | Maxent MX-42V1 42 in. Plasma Television
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
42 plasma tv
same problem here with my panasonic 42"? less than a month old and started about a week ago
Jan 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
Sep 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
855 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
