Error code SC542 What does this code mean and how do you fix this.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
That mean ther is proplem in fuser unit possible causes first thermistor is defictive and can't sense with temperture and may upper roller is broken and lambs tungestine halogen may broken solution and rarley thermofuse is defective solution replace it
Posted on Mar 25, 2011
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
SC542 Error
First fix fuser unit thermistor bad then service mode and rest set code
Feb 06, 2012 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
Now when i put my photocopy machine on the SC542 code error appears So i need a solution for this problem
Hi rfofie,
There's no specific brand or model you have mentioned on the issue that you needed help. However, I can provide you the meaning of the error code that you are getting. The SC542 error code is a Fuser Temperature Error. That means that the fuser did not warm up fast enough. You will have to replace the fuser to get rid off the error.
Hope it helps.
Thank you for using Fixya.
Mar 29, 2011 | Office Equipment & Supplies
What is error code sc542
I found some information on this error at http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
According to this website, the error code is due to a fuser temperature problem.
The Fix
In order to clear error SC542 follow these steps:
- Press and hold online + escape, then power on.
- Use up and down arrow keys to select SP2
- Press Enter
- Use up and down arror to locate SP5
- Press Enter
- Use up and down arrow keys to select 810
- Press Enter
- Confirm the selection
- Power off and on.
Kindly rate this solution, thanks!
Mar 08, 2011 | Ricoh Aficio 3025 All-In-One Laser Printer
SC542 error code
Without a model, I can't give you a lot of information, but I am assuming it is a Ricoh machine (Possibly Lanier/Gestetner, same difference), as that's the format of their error codes. An SC542 error code is a Fuser Temperature Error, meaning that the fuser didn't warm up fast enough. It is extremely likely that you will have to replace the fuser unit before the error code will go away. Please give me a model number if you need more information and I will try to be a bit more precise with the information. Thanks.
Feb 28, 2011 | Office Equipment & Supplies
I have a xerox machine for ricoh mp 1600 le. now i have a error of 542. so please tel me what is the problem of xerox machin?
SC542 code on Ricoh's means that the fuser unit is not heating up properly. The fusing unit is the part that "fuses" or fixes the toner onto the paper and is located right where the paper exits your machine. Most of the time the SC542 code means that the thermister(s) in the fusing unit have failed. The thermister measures the temperature in the fusing unit. When these go bad the machine can not "see" the unit heating up so it throws the code. The thermisters will need to be replaced and the code cleared out from the machines memory by gong into the service mode. I would recommend calling your local service provider to effect repairs.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Office Equipment & Supplies
Ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Nov 19, 2009 | Ricoh Aficio 2015 Copier
Error sc 547
Found this from:
http://slayo.com/ricoh-cl4000dn-error-code-sc542.html
Ricoh CL4000DN Error Code SC542
Turns out error SC542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won’t come ready until the prior error condition is cleared.
A few phone calls with our local Ricoh service rep, and he admitted that the printer might trip this error in a power brownout.
The printer was less than 30 days old and the error was caused by the brownout or the fuser failed. I kept calling the Ricoh rep, and they finally gave me the magic keystrokes over the phone.
I did the magic keystrokes, cleared the error code, and the printer worked fine. It’s been working great for a year now.
I hope someone else who has this problem finds this page and is able to fix the problem also. I didn’t find any help on the net when I searched.
The Fix In order to clear error SC542, you must perform procedure 5810.
  • Press Enter
  • Press Enter
  • Press Enter
  • Power off and on.
The error code is now cleared.
Hope this helps!
WizardRepair
Jul 17, 2009 | Ricoh CL4000DN Laser Printer
k24674
jasbo
jasbo
