Make sure the drain tube for the box is not clogged in the engine compartment firewall left side the AC condinsor has to bleed off water because of condensation on it from being in use,, otherwise u would have water with anti-freeze from the heater core if it was leaking ! but just water its the AC condinsor, lot of junk gets in the box from the vents and sometimes cases blockage
90 Cavalier leaking (clear) water in floor board. Left side front floor carpet and jute is wet. I found that the seal at bottom edge of heater core/AC housing leaking. By the way, heater core is new, as well as hoses/clamps. This may be what caused the leak. Not replacing housing bottom seal.. Any way I am going to silicone it this time. Mainly because the seal is no longer available. I will let yall know if it worked soon. db.
