Question about RTO Atwood DSI-RV Water Heater-6 Gallon
HELLO I HAVE A GC6AA-10E IT HAS A CRACK AND LEAKS SO I AM GOING TO USE A GC6AA-9E THE 9E DOES NOT HAVE A BOARD OR GAS VALVE SO I AM GOING TO USE THE BOARD AND VALVE FROM THE 10E MY RV TECH SAYS HE CAN MAKE IT WORK BUT HE WANTS A WIRING DIOGRAMDO YOU HAVE ANY INFO TO HELP WITH THIS?? THANK YOU ANNETTE
  • RTO Master
  • 6,674 Answers
Try this link and open PDF file and print wiring diagram. (page 7)
http://www.atwoodmobile.com/manuals/waterheaters/MPD%2093050%20PS%204.9.09.pdf
Posted on Mar 31, 2011
My hot water keeps shutting off after I start it. It runs like 15-30 seconds. What's up?
Sometimes that will happen if there is not enough (or any) water in the tank. Also, there might be a little air in the water line(s) if you had the thing apart. Keep trying. Good luck.
Jan 24, 2018 | Water Water Heaters
I have a gc6aa-10e hot water heater. I only get about 40 sec of hot water. I have raplaced check valve and put new thermostats in the water heater. I really dont know what else i should check. Need help...
Here is website for brochure and support center. http://www.atwoodmobile.com/water-heaters/atwood-water-heaters-brochure.asp
If it's electric it sounds like the elements.
Apr 23, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have atwood GC6aa-9e, will not fire the ignition tries 3 sets
Have you tried temporarily removing the thermal cut-out from the circuit to see if ignites then? It's the little resistor looking thing inside the plastic sleeve/cover that runs to thermostat. Disconnect it from the thermostat terminal, and from wire that is on the other end, and you should be left with a female spade connector at end of that wire. Connect that directly to thermostat terminal where the other part was connected, and try it. If it works, the thermal cut out is no good and needs to be replaced for safety reasons, in case of flame out of control, it blows and shuts gas valve off.
Jun 06, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a atwood hot water heater GC6AA-10E its o...
Does yours have the little cut-out diode looking thing in the plastic jacket installed between power wire and thermostat? If yes, remove it from the circuit and connect female spade of wire, to male spade of thermostat,(just removing it to by-pass it) and try it now. Let me know what happens.
May 20, 2010 | RTO Atwood Water Heater - 6 Gal LP
I have a GC6AA-9E and the Pop off valve lifted and sprayed all the electrical components and now the igniter will not spark. Any ideas where is the best place to start troubleshooting the controls.
Look for the little round temp switch inside little plastic sleeve, below pressure relief valve . Look where is plugs into at both ends carefully. Now disconnect it (take it out of the circuit) and hook the one end, to terminal where other end went to. Now try it.
Jan 04, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwood GC6AA-9E water heater isnt working properly
The ignitor is also a flame sensor. If it's not working to ignite, good chance it's not sensing flame to keep gas flowing as well. Could also be board.
Sep 09, 2009 | RTO Atwood Water Heater - 6 Gal LP
Changing heating Element
1-800-325-9250call this number and they can tell you what you want.
Apr 29, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
551 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
