I just need the steps involved in sending a fax of 4 pages.
3 Suggested Answers
emissionwiz
  • 79865 Answers
SOURCE: Please help me send a fax on my HP 5610
Send a fax
You can send a fax in a variety of ways. Using the control panel, you can send a blackand-
white or color fax from your HP All-in-One. You can also send a fax manually
from an attached phone. This allows you to speak with the recipient before sending
the fax.
If you frequently send faxes to the same numbers, you can set up speed dial entries.
For more information on setting up speed dial entries, see Set up speed dialing.
Send a basic fax
You can easily send a single- or multiple-page black-and-white fax by using the
control panel, as described here. If you want to send a color or photo fax, see the
onscreen HP Image Zone Help.
Note If you need printed confirmation that your faxes were successfully sent,
enable fax confirmation before sending any faxes. For more information, see
Print fax confirmation reports.
Tip You can also send a fax manually from a phone or by using monitor
dialing. These features allow you to control the pace of your dialing. They are
also useful when you want to use a calling card to charge the call and you
need to respond to tone prompts while dialing. For more information, see Send
a fax manually from a phone or Send a fax using monitor dialing.
1. Load your originals, with the print side up, into the document feeder tray. If you
are sending a single-page fax, such as a photograph, you can also load your
original on the glass.
Note If you are sending a multiple-page fax, you must load the originals
in the document feeder tray. You cannot fax a multiple-page document
from the glass.
2. Press Fax.
Posted on Oct 10, 2008
mickspaceNET
  • 115 Answers
SOURCE: Fax machine having difficulty to send and receive multi -pages
it is possible that the memory is corrupted, Or the ECM (Error Correction Mode) is not enabled,
What happens when None go through, is there a jam? or does it just drop the call.
Maybe setting the machine to print a Confirmation page will help to isolate the problem?
could also be the Phone line, is this a direct line?
What happens when you move the machine to another phone line.
Do this happen when you try to print?
Here are the basic specs of the machine?
The Transmission rate 3 pages per minute,
64MB of memory
(I have seen faxes bog the memory because of compression and dpi, I dont think this is the problem here)
Available Compression MH, MR, MMR,
DPI Modes :200X100 dpi, 200X200 dpi, 300X300 dpi
This is the User Manual for this machine..
http://www.lexmark.com/publications/pdfs/x34x/eng/ug.pdf
Posted on Oct 24, 2008
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
If you press Black Start, the
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
I wanna send a fax
Sending Faxes.
* Flow of Sending Faxes.
The operation flow of sending faxes is as follows.
Step 1:
Load the original to send on the Platen Glass or the ADF.
Step 2 :
Adjust the fax quality and scan contrast.
Step 3 :
Dial the receipent' s number.
Step 4 :
Send Faxes
- Using the Platen Glass
1) Press the Color or Black button.
If you have two or more pages of the original, load the next page on the Platen Glass and press the Color or Black button
2) After scanning all the pages of the original, press the OK button to send the fax.
- Using ADF
The fax is sent automatically.
* Before sending Faxes
- Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
** Adjusting the Scan Contrast
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among the 3 contrast levels.
1) Press the FAX button, then press the FAX Quality button.
2) Press right or left arrow ot select the contrast.
Pressing the left arrow button decreases the contrast, and pressing the right arrow button increases the contrast.
3) Press the OK button.
** Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
1) PRess the FAX button, then press the FAX Quality button two times.
2) Press the right and left arrow keys to select the resolution.
FAX RESOLUTION - STANDARD
Standard : Suitable for text-only documents.
FINE : Suitable for fine-print documents.
PHOTO : Suitable for photographs.
*Sending Faxes - There are 4 methods for sending functions
a) Memory sending
b) Manual sending
c) Dialing the coded speed dial
d) Redial
a) Memory sending
1) Prepare for faxing
a) Turn on the machine,
b) Load the original on the Platen Glass or the ADF.
Note : You cannot scan double-sided documents from the ADF.
c) Press the FAX bitton.
d) Adjust fax settings as necessary.
2) Start faxing.
a) Dial the receipient's number using the Numeric buttons or coded speed dialing.
b) Press the Color button for color sending, or the Black button for black and white sending. I
c) When the following message is displayed, lad the next page on the PLaten Glass.
Scan Next -> Start
Transmit-> OK
If only one document go to step f).
d) Press the same button as you pressed in step b).
e) Repeat step c) and d) to scan in all pages of the document.
f) Press the OK button.
Manual Sending
1) Connect a telephone to the machine.
2) Prepare for faxing.
a) Turn on the machine.
b) Load the original in the ADF,
c) Press the FAX button.
d) Adjust the fax settings as necessary.
3) Lift the handset of the telephone connected to the machine.
4) Dial the receipient's number on the telephone.
5) Talk through the handset to the recipient.
If you hear a high-pitched signal instead of the recipient's voice, go to step g),
6) Ask the recipient to set recipient's fax machine to receive faxes.
7) When you hear a high-pitched signal, press the Color button for sending color sending, or the Black button for black & white sending. Then hang up the handset.
Dialling The Coded Speed Dial
1) Prepare for faxing.
2) Press the Coded Dial button.
3) Press the Numeric buttons to enter the two-digit code (00-19) assigned to the number you want to dial.
4) Press the Color button for color sending, or the Black button for black & white sending.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Nov 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
I need to know how to send a Broadcast fax to multiple numbers
This is right from the manual:
You can use the Multiple Send feature, which allows you to send a fax to
multiple locations. Originals are automatically stored in memory and sent
to a remote station. After transmission, the originals are automatically
erased from memory.
1 Press Fax.
2 Load originals face up into the ADF, or place a single original face
For details about loading an original, see page 5.1.
3 Adjust the document resolution and darkness to suit your fax needs.
See page 9.1.
4 Press Menu until Fax Feature appears on the bottom line of the
display and press OK.
5 Press the Scroll buttons until Multi Send appears and press OK.
6 Enter the number of the first receiving fax machine and press OK.
You can use speed buttons, speed dial numbers, or group dial
numbers. For details, see page 10.2.
7 Enter the second fax number and press OK.
The display asks you to enter another fax number to send the
document.
8 To enter more fax numbers, press OK when Yes appears and
repeat steps 6 and 7. You can add up to 209 destinations.
Note
You cannot use group dial numbers for another fax number.
9 When you have finished entering fax numbers, select No at the
Another No.? prompt and press OK or Start.
The original is scanned into memory before transmission. The
display shows memory capacity and the number of pages being
stored in memory.
10 If an original is placed on the scanner glass, select Yes to add
another pages. Load another original and press OK.
When you have finished, select No at the Another Page? prompt.
The machine begins sending the fax to the numbers you entered in
the order in which you entered them.
Manual - see page 54
Dec 15, 2008 | Samsung SCX-5530FN All-In-One Laser...
Send a fax
the fax.
Send a basic fax
from the glass.
2. Press Fax.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Faxing to several numbers
Sending Broadcasting Faxes:
Using the BROADCASTING BUTTON on the control panel you can use the broadcasting fax feature. 1. Load the document(s) face down into the ADF. 2. Adjust the document resolution to suit your fax needs.Press BROADCASTING on the control panel.4. Enter the number of the remote machine using the number keypad. 5. Press enter to confirm the number.The display ask you to enter another fax number to send the document. 6. To enter more fax numbers, press 1 to select "YES" and repeat steps 4 and 5. You can add up to 10 destinations. NOTE: You cannot use group dial numbers for another fax number. 7. When you finish entering fax numbers, press 2 to select "NO" at a "ANOTHER NO" prompt.
The document is scanned into memory before transmission. The display shows the memory capacity and the number of pages being stored in the memory.
The machine begins sending the document in order of the numbers you entered..Hope this helps
Oct 08, 2008 | Samsung SF-560 Plain Paper Laser Fax
Broadcast Fax Sending
Change the resolution to STANDARD. This will cut your send times by 50%
Sep 06, 2008 | Symantec Winfax Pro 10.03 (winfax10.03)...
Cannot receive faxes
Step one: Check the fax number
Make sure the fax number is correct; include any numbers that you have to dial to use the telephone, such as an area code, access codes for outside lines or long-distance services, and so on. If you have to dial a particular sequence of numbers to make a telephone call from that telephone line, you also have to dial that sequence of numbers to send a fax.
If the issue is resolved, you do not need to continue troubleshooting.
If the number is correct, continue to the next step.
Step two: Dial the number manually
Instead of using a speed dial setting or sending the fax from the computer, dial the number manually from the product control panel.
If the fax sends when you dial the number from the control panel, follow these steps to recreate the speed dial setting and insert pauses in the number.
On the product control panel, press the Setup button.
Press the Left Arrow button ( ) or Right Arrow button ( ) until Speed Dial Setup appears on the control panel display, and then press the OK button.
Press the Left Arrow button ( ) or Right Arrow button ( ) until Individual Speed Dial appears on the control panel display, and then press the OK button.
Press the Left Arrow button ( ) or Right Arrow button ( ) to select an unassigned speed dial entry, and then press the OK button.
Use the product keypad to enter any numbers that must be inserted before the fax number, such as an area code or access codes for outside lines or long-distance services, and then press the Redial/Pause button to insert a pause.
Enter the rest of the fax number, using the Redial/Pause button to insert pauses between the numbers, and then press the OK button.
Enter the name of the speed dial setting, and then press the OK button to save the speed dial setting.
Try to send the fax again.
If the issue is resolved , you do not need to continue troubleshooting.
If the issue is not resolved , continue to the next step.
Step three: Run a fax diagnostic test
Press the On button ( ) to turn on the product, and then make sure the product is correctly connected to the telephone jack.
Make sure that there is plain white paper in the input tray.
On the product control panel, press 6 , and then press 6 again.
This selects the Tools menu and then selects Run Fax Test .
The fax diagnostic test page prints.
Review the results of the test.
If the result of the fax diagnostic test is All Pass , skip to Step four: Reinitialize the fax.
If the result of the fax diagnostic test is a failure, a page prints that describes the issue and offers possible solutions. Follow the solutions on the printout.
If the solutions on the printout resolve the issue, you do not need to continue troubleshooting.
If the solutions on the printout do not resolve the issue, continue to the next step.
While the product is on, disconnect the power cord from the back of the product and from the electrical outlet.
Make sure that the telephone cord is fully inserted into the port labeled 1-Line on the back of the product.
Connect the power cord to the back of the product, and then connect the power cord to the electrical outlet.
When the product is in the ready state, try to send and receive a fax again.
Step five: Test the send/receive functions
Use the product keypad to send a fax. Watch the product control panel display and listen to the sounds the product makes.
If the product is working correctly, the following events occur.
When the product begins to dial, a dial tone is audible, followed by the sound of the product dialing. A Dialing message appears on the control panel display.
When the receiving fax answers the call, the product and the fax exchange tones. A Connecting message appears on the control panel display. During this phase, the product and the fax compare capabilities, exchange information about how to send the fax, and try to establish a reliable transmission speed.
After the connection is established, the product sends the pages of the document. Messages appear on the control panel display that indicate the status, such as Sending page 1 .
Review the results of the fax.
If the fax is transmitted successfully, continue to the next step.
If there is no audible dial tone or the receiving fax does not answer the call, try sending the fax to a different destination. If this second attempt also fails, continue to the next step.
If the receiving fax answers the call and begins beeping, but the Connecting message does not appear on the product control panel display, the product is not detecting the tones from the receiving fax. Continue to the next step.
Step six: Use an analog telephone service
HP Fax and All-in-One products are designed to work with analog telephone services and might experience some difficulties when they are connected to phone lines with digital services. Make sure the product is connected to an analog telephone service.
To obtain digital services information or support, contact the telephone service provider or system administrator.
Step seven: Check the phone cord and fax connections
Disconnect the telephone cord, and then examine the connector on the end of the cord. Make sure the cord only has two wires.
Figure 1: Telephone cord with two wires
Figure 2: Telephone cord with four wires
If the cord has four wires, replace it with a two-wire telephone cord.
If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
Make sure the fax is connected directly to the telephone jack by a telephone cord. Connect the cord to the 1-Line port on the back of the product.
Figure 3: Fax only
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
If other devices need to use the same telephone jack, make sure they are connected to the 2-Ext port on the back of the product.
Connect a single-line telephone to 2-Ext , and then pick up the receiver and listen for a dial tone. Make sure you are able to dial out using the telephone keypad. If you hear a dial tone and are able to dial out using the phone, the product is properly connected to a working telephone cord and telephone jack.
Figure 4: Fax and telephone
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
5 - Telephone
Figure 5: Fax and PC or modem
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
5 - PC or modem
If you change any cable connections, try sending and receiving a fax again to make sure that the issue is resolved.
Step eight: Remove any other devices from the telephone line
If any other devices, such as a telephone, an answering machine, or a modem, are connected to the telephone line, remove each device.
NOTE: Remove each device even if it is in another room, connected to another telephone jack, or connected using a line splitter.
Connect the product to an analog telephone line by connecting one end of the two-wire telephone cord directly to the telephone jack and then connecting the other end of the telephone cable directly to the 1-Line port on the back of the product.
Try to send a fax again.
Step nine: Perform a partial reset of the product
A partial reset of the product returns all fax settings to the default values. It might be necessary to reset the language and country/region settings after the partial reset is complete.
Disconnect the power cord from the back of the product.
Wait 20 seconds, and then press and hold # and 3 on the product control panel.
Connect the power cord to the back of the product, and then release the buttons when the product turns on.
The product is reset to factory defaults.
Try to send and receive faxes again. If the problem still exists, continue to the next step.
Step ten: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Aug 05, 2008 | HP Office Equipment & Supplies
Hi, Remote Fax Error being displayed
NOTE this option may vary to printer try USING OPTIONS TO SET CHANGES
To resolve the problem, try the steps below. After each step, try to send a fax again.
1. As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
* Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
2. Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
3. Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
1. Press the Fax button, then press Options untill u see ADVANCED FAX mode.
2. Press Select.
3. Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
4. Change the setting from Yes to No using the + (right arrow) button.
5. Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
4. Lower the fax transmission speed 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
1. Press the Fax button, then press Options untill u see ADVANCED FAX.
2. Press Select.
3. Press Options untill u see until MAX SEND SPEED appears on the LCD display.
4. Change it to 9600 BPS using the - (left arrow) button.
5. Press Select.
5. Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
1. Press the Fax button, then press untill u see to get to ADVANCED FAX.
2. Press Select.
3. Press untill u see ERROR CORRECTION appears on the LCD display.
4. Change the setting from On to Off using the + (right arrow) button.
5. Press Select.
Nov 16, 2007 | Lexmark X4270 All-In-One InkJet Printer
26 people viewed this question
k24674
jasbo
jasbo
