Question about Ovens
It heats to 200 then cuts out - Ovens
    Champion:
  • 235 Answers
Does it come back on soon after or not until the oven has cooled right down?
Posted on Mar 25, 2011
I have a Garland Mater 200 electric oven and the fan continues to run even with the door open. Is there a switch / sensor that controls that?
https://www.manualslib.com/manual/55869/Garland-200.html?page=103#manual
This web site had a manual that may answer you question. It seems that here is a heat/cool switch. The cool switch is designed to function to cool the oven down by running the fan with the door open. If you close the door, it will heat so the door has to stay open.
Aug 20, 2017 | Garland Ovens
My oven wont heat up past 200 degrees. Suggestions
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Mar 04, 2011 | GE Monogram® ZMC1095BFBB /...
Oven doesn't preheat over 200 degrees
heatman101
Jan 04, 2011 | Maytag MEW5527D Electric Single Oven
The oven has a digital mode for the temperature and timer. However, it shuts down by itself on temps higher than 350º in 30-50 minutes. If it is on a higher temp, like 400-450º, it will shut...
The ribbin connection terminal betweenth control board and the display is losing electrical connection with heat. Try pushing the ribboin connectors deeper into the recepticles on both the display and the conrol board.
It may just be that the ribbon electrical strip itself is failing at temp and separating. You should be able to go to a serious elctronics supply store / maybe even radio shack and get a ribbon strip that you can cut to length and install. Ask for assistance as you also may need to make adapters on both ends of the ribbon to go from ribbon recepticles to PCB recepticles. MUCH cheaper than P2500 / $200 US for sure.
Thanks for using FixYa.
Kelly
Mar 20, 2010 | Ovens
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Magic Chef oven won't heat up past 200 degrees
You obviously have one or more elements not working, you need to test same, and replace as req'd.
Dec 12, 2008 | Magic Chef Ovens
GE JKS06 won't heat up past 200
Hi.
Could be that main oven stat is faulty, and also there is a possibility that the thermal overheat stat is coming in sometimes caused by poor ventilation.
Also there is sometimes a secondary element fitted to cookers which is not always obvious.
More investigation is needed.
Nov 19, 2008 | GE JKS06BFBB Electric Single Oven
Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
Ovens Logo
32 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
