Question about TruTech PLV16190 Television
Tv comes on but only shows a pic for a second or two and has no sound aswell pulled off the back and the only thing i see wrong is two compasitors are bulged up on the top and they are both next to each other on the small white circut board.
  • 718 Answers
You have found the problem.
If this set is under warranty you should return it to get it repaired/replaced by the seller. If not then;
This sounds like the power supply board has failed. The electrolytic capacitors on the board need to be replaced.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(soldering ) or have a friend with knowledge/skill you can fix it. If you can not solder then you can replace the board.
>Unplug the set and any cables.
>Remove the back cover.
>look at the capacitors on the power supply board. If the top of any of them are bulging up then that is the problem.
>You will have to replace ALL the electrolytic capacitors except for perhaps the large one.
>Disconnect and remove the power supply board. Handle by the edges to prevent contaminates and static electricity.
> Use ones with the Low Equivalent Series Resistance ESR rating
> Use ones with the same farad rating
> Use ones with the same or higher voltage rating
> Use ones with high temperature rating
> Install one at a time to prevent mix-up and keep the polarity correct.
> Leave a space between the PC board and the bottom of the capacitors for expansion. They heat up.
> Replace power supply board and reconnect cables..
> Replace back cover.
THIS IS AN INDUSTRY WIDE PROBLEM AFFECTING MANY COMPANIES AND PRODUCTS.
Sources for some good capacitors are www.digikey.com or NTE. Try nteinc.com for a local outlet of NTE products.
You can also search for other sources. Some companies even sell all the capacitors in a kit.
Total price of parts should be < $30.00
Yes you can buy a new power board but if the capacitors have not been replaced they will eventually fail also.
Posted on Mar 25, 2011
I have a Samsung LTF520HB03 LED TV. It started out taking 10-15 minutes for pic to come on. After a month or two, the pic and sound started going off by itself. Now no pic at all. There is a clicking every...
Flat screen TV's unless under warranty are not repairable in a cost effective manner, even if you could find someone who can repair. Time to shop for another TV.
Oct 04, 2014 | Televison & Video
My 65" mitsubishi tv model ws65517 went off and
Needs to be serviced by tech, Anything wrong will shut it off like that.
Lamp light blinking red
From your description it sounds like the lamp bulbs needs to be replaced.
You need one of these:
http://www.amazon.com/Hitachi-50VS69-Watt-RPTV-Replacement/dp/B006C58MOI
NOTE: DO NOT TOUCH THE GLASS PART OF THIS BULB. The smudges from your fingers can show up on the image projected onto your screen and make things look blurry.
Once you have the new bulb then turn off the TV and unplug it. On the back panel there is a rectangle on the left with a screw holding it on. Use a philips head screwdriver to loosen the screw then slide the rectangular panel to the left and pull it off. Inside will be the old lamp bulb. Use the screw driver again to remove the screw holding the lamp bulb in and pull the lamp bulb out (it may be hot). Insert the new bulb and then screw it back in. Place the panel back on and screw it back in as well. Make sure the screws are tight or the TV may not turn on. You can now plug the TV back in and turn it on. If done correctly this should resolve the issue.
May 07, 2013 | Hitachi 50VS69 50" Projection HDTV
Hi my lg lcd model no 42LB9DE works fine apart from 1 tv channel has perfect pic but no sounds have re-tuned tv many times to no avail... any ideas ? Tv antenna is is proper working order only 1 channel i...
by reading your problem the main thing is that your tuner of the tv is faulty or it can not tune the specific frequancy of the channel and its audio frequency just replace your tuner card
Feb 16, 2011 | LG Televison & Video
TV turns off while watching it then turns back on after abt 1 min
TV needs new lamp as symptom shows existing lamp is weak and causing repeatedly on-off
Please replace lamp in TV, replacement procedure is written in user manual and it is not difficult.
Always buy Sony original lamp for TV safety.
Let me know if you need further help.
Thanks.
Sep 22, 2009 | Sony Televison & Video
Tv want show picture tv power light stays on but no pic no sound
on your deflection board ck capacitors cp150 cp114 cp120 if cp 150 is puffed up on top it is Bad 2200uf16v other 2 caps are 220uf 35v replace all 3 .Heres another thing you can try on front panel Press and hold vol-and ch- with TV off, hold both at same time wait for 10secs untill TV comes back on.
Sep 22, 2009 | RCA D52W19 52" Rear Projection Television
I cant get my ps3 to reset. I was using it on a HDTV and I swicthed it back to a regular tv using AV cables and it will not show pic. just sound. Everybody says to reset it by pushing the button on the...
Try using a different Tv.
"First beep it turns on second beep nothing and third beep turns off.will not reset."
Your friends are wrong, pressing the button at the front of the console only turns the console on and off. If the problem doesnt change then contact the sony customer helpline.
Jul 29, 2009 | Sony Video Game Consoles & Games
TruTech PLV16190 Television Logo
49 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
