Water is only trickling through - Heating & Cooling
  • Anonymous Aug 03, 2008
    WATER IS NOT DRAINING
Well my air conditioner was not draining at all and my husband took it out of the window and took the cover off,there was some sort of thick sliming nasty stuff in it that was causing it to be clogged up.It just a suggestion you can check it.
Posted on Sep 13, 2008
Water does not flow
Sounds like air in the line.....the filter may be cracked/damaged, or not quite seated...?
since you've tried 2 new ones....I'm gonna bet they are not quite the correct ones for your fridge.
Sep 07, 2012 | GE GSHF5KGXBB (254 cu ft) Side by Side...
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
Cold water only trickles in
Assuming you have good water pressure to the inlet valve, you probably have a blocked or faulty inlet valve...Not a big job....Good luck...Nomess
May 16, 2010 | Washing Machines
Cold water will only trickle into washing machine
Check your water pressure if thats good check the screens on your hoses, if thst good go to the water inlet valves that allow water into your tub
Jun 09, 2009 | Washing Machines
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
i believe on the water valve where your hoses connect,they have screens or filters inside maybe it is plugged
Mar 30, 2009 | Whirlpool LSR7333 Top Load Washer
Automatic Trickle Questions
o you multitask while you wait for the shower to get hot? Brush your teeth? Make the bed? Maybe even pick out your clothes or iron a collar? Many of us do—and don’t know that while we’re feeding the dog or grabbing that second cup of coffee, two-and-a-half gallons of hot water per minute are funneling down the drain. The automatic trickle reduces the flow of the water as soon as it reaches a comfortable 95 degrees. This way your hot water is no longer running down the drain while you’re away from the shower. The automatic trickle allows your showerhead to warm your shower without wasting hot water and tell you (hear) the when your shower is ready. Evolve is the leading manufacturer of this kind of products.
Aug 27, 2008 | Baldwin Hardware 3755 Estate Collection...
Heating & Cooling Logo
256 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
