The following message appeared while logged in to a website CONNECTION ERROR=Can't create a new thread (errno 12); if you are not out of available memory, you can consult the manual for a possible OS-dependent bug. I closed down and restarted my computer, but every time I try to connect to the website, the same message appears. (It does not happen when I try to access other websites). Pleas calrify what it means Thank you
iqbal_del
  • 655 Answers
SOURCE: Installed Fontographer 4.1.5 WIN from
shalomodoo,
This product is designed to run on the following operating systems:
  • Windows NT 4
  • Windows 98
  • Windows 95
If you are using other than these OS it might cause problem.
  1. Try to uninstall then re-boot
  2. Make re-install.
  3. if the above steps does not fix problem, then call the vender for your OS support.
Thanks
Iqbal
Posted on Apr 16, 2008
Ajkill
  • 2035 Answers
SOURCE: I am a new customer
1. Check Firewall blocking Ports
telnet <ip-of-your-juniper-sa> 4500
telnet <ip-of-your-juniper-sa> 443
2. Check the Juniper Event Log Files.
3. Do a "Session Recording" on the Juniper to see what happens while user tries to connect
4. Check Juniper Knowledgebase
nc.windows.app.23663 - Network Connect is already running on the client. Please terminate your existing session before starting a new one.
nc.windows.app.23704 - Connection attempt timed out.
nc.windows.app.23705 - Unable to display connection information.
nc.windows.app.23707 - Cannot open a connection to the NCService component.
nc.windows.app.23708 - Cannot connect to the secure gateway.
nc.windows.app.23709 - Cannot open a connection to the secure gateway.
nc.windows.app.23710 - Unable to retrieve connection information from the secure gateway.
nc.windows.app.23713 - Proxy authentication required to connect to the secure gateway.
nc.windows.app.23714 - Failed to connect to the secure gateway.
nc.windows.app.23715 - Unable to retrieve connection information from the secure gateway.
nc.windows.app.23786 - The Network Connect NCService component is not running.
nc.windows.app.23787 - Cannot start the Network Connect service. Please re-install Network Connect.
nc.windows.app.23791 - The secure gateway denied the connection request from this client.
nc.windows.app.23792 - Failed to connect to the secure gateway.
nc.windows.app.24044 - Network Connect could not initialize the Type of Service (TOS) feature.
nc.windows.app.24045 - Network Connect could not disable the Type of Service (TOS) feature.
nc.windows.app.24058 - You must reboot your computer to disable the Type of Service (TOS) feature.
nc.windows.app.24059 - You must reboot your computer to enable the Type of Service (TOS) feature.
nc.windows.app.24062 - Launching Network Connect will automatically terminate your W-SAM session, which may render some network resources unreachable.
Posted on Jul 17, 2008
ginko
  • 19396 Answers
SOURCE: Error Code 0x80004005
The issue is with google earth, is a fault in the software that comes up with certain windows installation.
I report from Google groups:
It sounds like Google Pack might be having an issue with installing
Google Earth. You can try downloading Google Earth directly at
http://dl.google.com/earth/client/current/GoogleEarthWin.exe
If you're unable to download anything with Google Pack, you may want
to try looking in the awesome Google Pack Help Center for more
information. You can find the Google Pack Help Center at
http://www.google.com/support/pack/?hl=en"
Also do the following, install it manually from
Control Panel > Add/Remove Programs > Add Program from CD/Floppy Diskette
thanks
Posted on Sep 03, 2008
SOURCE: I am using Norton Antivirus
Turns out the whole problem was related to my version of Norton (which I have run/updated without problem since 2005) suddenly becoming defective. Once I removed Norton with their remove tool on the Symantec website everything worked fine again. Thanks for your help
Posted on Dec 19, 2008
hmerchant110
  • 7191 Answers
SOURCE: "oops, this link appears broken" appears on many attempts to open websites
What is the url you are trying? I see no problem opening http://www.shutterfly.com
Posted on Apr 19, 2009
Why can't I set up a new Facebook account
Point your web browser at http://www.facebook.com
If another account comes up, log out of it by clicking the down-pointing triangle in the upper-right then clicking "Log Out."
You should be able to create a new account now. If you're getting an error message, what does it say?
Jun 26, 2014 | Facebook Social Network
I am trying to install Damn Small Linux onto my PC. I am running a mercury PVCLE266M-L V3.0 (http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=439#) 512MB...
you are using a trunicated (packages missing) server download.
get an offical copy of Ubuntu linux from on-disk.com and, your troubles will be over;
Jul 11, 2011 | Computers & Internet
I have windows xp and can't log on forgot the password how do I go around that and log on to windows ???
Please restart the Computer and press the Ctrl+Alt+Del as the login window appears.
Then enter the username as Administrator and Password as password.
Then after login you may create a new user account
Dec 14, 2010 | YouTube Videos
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Buenas noches, apenas enciendo mi portatil dell 700m me pide clave de bios, la lleve a un tecnico y creo que no la trabajo bien y no la logro desbloquear, que puedo hacer?? soy de colombia y la verdad no...
Use a floppy disk or USB memory key to create a password reset disk using the following Microsoft instructions: How to Create a Password Reset Disk
The easiest way to recover from a lost password situation is to use a password reset diskextlink.gif. If you have a reset disk, follow these steps:
  1. At the Windows logon screen, click Reset password.
  2. Insert the recovery diskette or USB key.
  3. Follow the instructions on-screen to create a new password.
  4. Log onto the account using your new password.
new_note.jpg Note: Password reset disks are valid for the account they were created on. If you use a password reset disk to recover your password, you do not need to create a new reset disk afterwards.
Issue 3: Resolve Error: The User Profile Service Failed the Logon
The following Microsoft Knowledge Base Article provides instructions on how to resolve The User Profile Service Failed the Logon. User profile cannot be loaded error.
"Error message when you log on to a Windows Vista-based computer by using a temporary profile: "The User Profile Service failed the logon. User profile cannot be loaded"extlink.gif Article ID: 947215.
Issue 4: If You do not have a Password Reset Disk
If you have lost or forgotten your password, and a password reset disk is not available, reinstalling the operating system is the only recourse. For information on reinstalling Windows, refer to Dell Knowledge Base Article, How To Restore or Reinstall Microsoft® Windows® on a Dell™ Computer
Nov 07, 2010 | Dell Inspiron 700M Notebook
Can not log on to facebook when i log on get error message internet explorer could not find www.facebook.com
Facebook servers are down today 9/22 since 12:00 EST for an undisclosed problem.
CLICK HERE to check it's current availability
Engineers are working on it right now.
There is no word when it will back online.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@*%^
Sep 22, 2010 | Facebook Social Network
Printer problem - HP Photosmart 8150
If the printer cannot print or move any paper, follow these steps to display the Event Log. Otherwise, print the Event Log.
1. Press Menu until INFORMATION MENU appears.
2. Press Item until SHOW EVENT LOG appears. Press Select to show the Event Log.
3. Press - Value + to scroll through the Event Log.
4. Write down the error messages.
If you see a 52.X error then this indicates the following:
0 Laser/Scanner Error
1 Laser/Scanner Startup Error
2 laser/Scanner Rotation Error
ACTION:
1. Press GO. The page containing the error will automatically be reprinted.
2. Turn the printer off, and then turn the printer on.
3. Reseat the cables fort the Laser / Scanner Assembly.
4. Replace the Laser/Scanner Assembly
Sep 21, 2009 | HP Photosmart 8150 InkJet Printer
I always get the following message at step No. 4 (in accordance with the installation software direction): ?Your new router does not appear to be connected properly ERROR 322 New router cannot be detected....
Connect with an ethernet cable then type http://192.168.1.1 into a web browser and see what happens. If you get a log in screen leave the username blank and use the password 'admin' (without the quotes). this will tell you if the router is accessable to the computer.
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
SBS 2003 and Networking evert logs??
Try going to Start, Right click My computer, choose Manage>System Tools>Event Viewer.
If that doesn't work for you, you could try right clicking my computer, mapping the network drive, and creating a link to your network server...
For more specific info, please consult this link.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 26, 2009 | Microsoft Windows Small Business Server...
Windows dvd maker
What OS are you using? Ultimate, Premium, Basic?
Windows DVD Maker has stopped working Issue : While trying to create DVD in Windows DVD Maker in Vista, or while creating a DVD from Windows Movie Maker, which uses Windows DVD Maker, the burn process stops with error message.
Error message : " Windows DVD Maker has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. "
Cause : Windows DVD maker stops working because of incompatibility with one or more codec files which are outdated or incompatible with the particular project or the DVD Maker software itself.
Resolution :
These Codec files should be located and renamed to resolve the issue.
1. Open Start menu and type Event Viewer in the Start menu search bar. Open Event Viewer from the menu.
2. In the Event Viewer window Click on Windows Logs in the left panel
3. Click on Application Logs under Windows Logs
4. Locate error messages listed in the Central panel of the Event Viewer window and double click the error to check if this is log is related to DVD Maker.
Sample Error Log :
Problem signature
Problem Event Name: APPCRASH
Application Name: DVDMaker.exe
Application Version: 6.0.6000.16386
Application Timestamp: 4549b5b0
Fault Module Name: nevideohd.ax
Fault Module Version: 4.6.15.0
Fault Module Timestamp: 459bb828
Exception Code: c0000005
Exception Offset: 00008b89
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1062
5. Locate Fault Module name, it should be a file with extension .ax.
6. Once the file name is identified, try to locate the file in C:/Windows/System32 folder. ( Please click on Show Contents if the files are not listed Automatically ).
7. If the files are not listed in System32 folder, search for the file, with search containing system files and folders.
8. Locate the file and rename it.
9. Check if the issue persists. If the issue persists and the error message again appears, locate the new .ax file that is causing the issue from the Event Viewer, error log.
These steps will resolve the issue instantly without a restart.
Sep 18, 2008 | Computers & Internet
Computers & Internet Logo
536 people viewed this question
David Payne
David Payne
