Question about Kenmore 22422 Top Load Washer
Kenmore top load won't drain or spin
It clicks when you shut the lid, so whats next?
  • 2 more comments
  • puddin417 Jan 18, 2009
    How do I access the motor and water pump
  • Doug Miller
    Doug Miller Jan 18, 2009
    I have a kenmore heavy duty extra large capacity washing machine. model # 110.22292100, serial # cm 2937753, Type 107 The machine does not fully rinse or go to the spin cycle. It stops half way through the spin cycle.
  • money8614 May 27, 2009
    I have a Kenmore 110.22292100, the machine will agitate and go through rinse cycle, but will not continue to spin cycle(even If I manually turn dial) If I let it set for a while sometime is will spin for the rinse cycle but won't rinse after that. I have replace lid swith and its still fine(the machine make a buzzing noice when the lid is and closed on the spin cycle as if its want to go to spin. The pump and cold/hot valve; I also repalce earlier to stop leaking. I wante dto know is there a solenoid problem for the spin cycle? Please advise
  • Toby Norton
    Toby Norton May 11, 2010
    Does it make any noise when you put the machine into a drain spin?
  • 246 Answers
Since I have not heaqr back on this in a couple of weeks for clarification, I am closing it off my list.
Posted on Aug 18, 2008
It might be the lid switch. I had the same problem and I replace the lid switch and it worked.
Posted on Aug 05, 2008
Kenmore stylemaster 902202 will not spin, agitate or drain tub spins freely
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 07, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore washer front load 417 wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped
Feb 18, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 15, 2011 | Kenmore Washing Machines
How do I fix my Kenmore washer spin cylcle? It
if your machine is a top load , less than 15 yrs. You most likely need a new lid switch. The machine will not drain or spin if the top lid is open.
Dec 12, 2009 | Washing Machines
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore washer somtimes won't go threw spin cycle
kenmore washers have a 2min. drain before it spines if leting it drain for 2min does not work u proberly need a new lid switch. haundi24
Jul 03, 2009 | Kenmore 22422 Top Load Washer
My machine loads and agitates, but will not drain, rinse or spin
If this is a top load machine check the lid switch.
If you manually advance the timer to spin, open then close the lid, and get no spin, it is a bad lid switch.
If it does spin, report back for the next step.
Apr 21, 2009 | Kenmore Washing Machines
Kenmore washer will not spin
KENMORE 80 SERIES 110.92582110 - NOT SPINNING. I REPLACED THE TRANI, CLUTCH, COUPLER BUT I FORGOT TO PUT BACK IN THE AGITATOR WASHER. IT STILL WON'T SPIN SO WHAT NEXT
Jun 12, 2008 | Kenmore 23822 Top Load Washer
Kenmore 22422 Top Load Washer Logo
185 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
