Question about Amcor Heating & Cooling
I have an AMCOR unit, model number AF 11000E and in need of a replacement filter. I don't have a number for it, can you help me? It seems AMCOR is out of business ... thanks.
3 Suggested Answers
  • 1252 Answers
SOURCE: i need a instuction manual for my amcor portable
http://dl.owneriq.net/8/81da8c5e-7d0e-4373-a7d9-a4de1b988401.pdf
try this web site. I has the manual you are looking for.
Hope this helps ya
Posted on Mar 16, 2010
Testimonial: "thank you, very helpful, printed and stored."
  • 384 Answers
SOURCE: I have an AMCOR 1400E
dear sir
if your aircon compressor is working and it,s not getting cold then it can be cause of leakage in aircon system then need to refill freon on your system .
please contact to your area amcor dealer for get the benefit of your warranty period(if it is in under warranty)
thank you
hope answer the question
Posted on Sep 25, 2010
Hello I have an Amcor dehumidifier (at least 7 years old). It seems to be really struggling and is a lot less effective than it used to be. I don't have any means for cleaning it because the...
Sean, There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit,
turn the humidity extraction knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. As the unit is 8 years old and may to have have routine maintenance performed on it, on a regular basis.
I hope this helped you and thanks for choosing FixYa.
Aug 13, 2011 | Amcor AD400E Dehumidifier
Where can i get parts
Katsby, it depends on which parts you need and how old your Amcor AC is.
Since Sears sell Amcor, go online to www.searspartscentral.com. Be sure you have the correct model number of your unit when, searching for parts.
Thanks for choosing FixYa.
Aug 11, 2011 | Amcor MF8000E Air Conditioner
We need a replacement filter for our Sharp Air Conditioner Model AF - S60DX.
Karen, even though your model has been discontinued, you can still get a washable filter replacement for you AC Unit. Most hardware stores and home improvement stores sell a washable, mesh filter kit, that can be cut to size to fit your unit and hundreds of others. You'll probably have enough left over to make two filters, if necessary
Aug 01, 2011 | Sharp AF-S60DX Air Conditioner
Unit does not start, shows E2 error, can you help on what that code means and resolution
I have searched and searched and have not been able to find an Owner's Manual for your model Amcor Dehumidifier. I did discover that Haier and Fredrich both have similar models, So similar, I suspect Haier manufactured them. But, neither the Haier nor the Fredich's unit have any information concerning Error Code 2. Plus, the ratings for your Amcor model were not very good. Seems that Amcor is riddled with problems.
In any event, lets try to solve your problem. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and remove the water collection bucket and the air intake filter. Check the filter closely for significant dust and dirt buildup and clean it if necessary. Make sure the filter is thoroughly dry, before placing it in the unit. Leave the unit unplugged for at least 15 minutes or until the filter is dry. Then replace the filter, insert the bucket - making sure that it fits swaourely from top to bottom into the bucket holder. Plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, the 15 minute timeout has allowed the unit's electronics to reset themselves and they reverted back to the original factory settings. If so, set the controls to your liking and the unit should start and run like it should.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 17, 2011 | Amcor AHD45 Dehumidifier
Hello, i have a AMCOR KF 9000 BTU. And was wondering where do i put the water? and why do i need water in the unit?
Unless, AMCOR has recently made a dramatic change to your model, you don't add water to the unit. Your model acts as an air conditioner and a dehumidifier, all at the same time. It evaporates the water/humidity in the room's air and exhaust it out the vent hose. There is a drain pan, that collects any un-evaporated water, but that only needs to be drained if it's full. Which rarely occurs, unless the humidity is extremely high for a long periods of time..
Hope this helped you. Please let me know. Thanks.
Jun 10, 2011 | Amcor Heating & Cooling
The unit will not produce cold air. It only pushes out room temp air. Altough I am not an expert, I think it is the compressor, or the tempature control unit (thermostat?) The unit does seem to make an...
I have a Amcor AF 1200E air conditioner, it only blows warm air and it is real dirty on inside filters, we took out 3 filters but there is still dirt on filters behind these, do we take it apart to clean, I would like a manual , do youknow where I can download one at? thanks
Sep 06, 2010 | Amcor AF9000E Portable Air Conditioner
We purchased a Amcor Amcoraire Mini Split Unit ? 12000BTU However the Power Transformer Input: AC115-120v 60hz Output: 10.5v 550mA isn't working as per the installer and we can't seem to find it...
Hi, this is a 1-ton cooling unit per your numbers. If they just installed it and the line side (120 volts) is good but nothing on the secondary low voltage side, they should have replaced the transformer themselves? If it is a split system, it is normally on all splits to be located in the indoor unit control section. I can't tell you exactly, but look where the 120 volts come into the indoor unit and the high voltage wiring should be connected to it then stepped down to lower voltage. It may have a fuse on the circuit board that they blew when installing it. If you are not familar with electrical, I wouldn't attempt to make these repairs. You can look for a small plug in type fuse to see if it blew, it looks like one on your automobile. I would call this installer out and its there job to do this!! These transformers look different, there not all the same, but will have a black and white wire coming in, and several colored wires coming out for low voltage. It will be in the indoor unit. Keep me posted on what you find or if you need more help. How long ago was the unit installed?
Shastalaker7
Jun 15, 2010 | Amcor AF 12000E Portable Air Conditioner
Heating & Cooling Logo
57 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
