Question about Kirby G5 Bagged Upright Vacuum
How do you install the attachment hose? If you havea diagram you could email me, that would be great!!
Where does the hose attach on a royal extractor 7910 diagram?
To insert the suction hose open the cap on the top of the cleartank top nozzle assembly, insert the hose and twist. The water line pushes on to a quick release port on the side of the machine.
Jun 18, 2018 | Royal Vacuums
How to put on attachment hose
Here is a walkthrough on that with pictures:
Vacuuming Bare Floor with Kirby vacuum
You will need to take off the nozzle to attach the hose.
Install Kirby belt and nozzle
800-775-6586
GoodVac com
Dec 05, 2014 | Kirby Vacuums
My Lindhaus Diamante 300 has great suction but clogs
Sounds like you have some form of an obstruction in the hose ( i once found a tooth pick sideways in mine) most models allow for the hose to be disconnected from the vaccum itself, also make sure theres not a setting for attachments also, some models need the suction redirected.
Apr 08, 2010 | Lindhaus Diamante 300 Upright Vacuum
Can't find owner's manual. need to use my kirby g4 to inflate an air mattress. help
Remove power head and bag from motor install pig nose attachment on front where powerhead goes install hose on back where bag attaches put inflator tool on hose
Jul 06, 2009 | Kirby Vacuums
My hoover5134-900 there is no suction from the hose when I attach
Here is a link to an online manual at fixya. You do have to attach the hose and the diagram in the top right corner tells you how.
http://www.fixya.com/support/p40671-hoover_u5134_900_bagged_upright_vacuum/manual-4450/page-8
Dec 14, 2008 | Hoover U5134-900 Bagged Upright Vacuum
Soap/water solution pouring out on floor when trying to use hose & attachments
The attachment hose is torn right where it connects to the motor . And there should be a trigger on the end of the hose right below where it connects to the hand tool.
Oct 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
How do i use the attachments to shampoo my stairs
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier.
Instruction manuals available in DVD, VHS or book format by following this link,..
http://stores.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQcolZ4QQdirZ1QQfsubZ7656839QQftidZ2QQtZkm
Hope this helps...
Jun 22, 2008 | Kirby Vacuums
Utlimate g vacuum appholstery attachment
Hi!
Since you lost your manual, you may want another. They are available in DVD, VHS or book format. Check it out!
Hope this helps...
Marci
Jun 02, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
