Question about General Electric Dryers
I have an older GE dryer model DBXR463GB0WW that is making load sqeeking noises that reduce some after runing for awhile. How to know if it is the rear or front drum bearing or the drum slides that need replacing? How to get at both?
  • 156 Answers
SOURCE: older maytag dryer
2 things there first is noise the support rollers that old drum up and the pulley 4 the belt tightner needs replaced the dryng time as long as the dryer gitting hot is the vent going from dryer to outside pluged up
Posted on Feb 28, 2008
  • 319 Answers
SOURCE: Bosch nexxt model gas dryer - screaching noise coming from Bearing shield
call tech support
Posted on Mar 11, 2008
IFIXALL
  • 868 Answers
SOURCE: ge dryer makes grinding noise when drum is turning
If youve made sure that its not a roller thats dry or a belt idler pulley that dry,than yes its the motor,and oiling that will only make it worse.
Posted on May 21, 2008
SOURCE: GE Dryer model#DWSR483EA1WW
you need to replace the inner plastic "shell" and the teflon pieces that the drum rides on. The dryer drum has eaten thru the teflon slides, and has probably started eating the shell away also.
About $40 in parts available on line will fix the problem.
Posted on Jun 21, 2008
SOURCE: dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Posted on Jan 14, 2009
Noise in dryer model DBXR463GB0WW
Check the blower, something may be stuck in it or it may be broken, also check the 2 tank rotors that hold the tank in place, they may be damage or it may be a little bit of oil.
Mar 29, 2013 | Whirlpool Dryers
Dryer struggling to turn and making noise.
first off send the brand name and model number off of the dryer open the door and look around the opening where you put the clothes in and you'll see the model number.there is only one belt,you could have a bad roller,or a bad belt pulley or something in the blower wheel from running the dryer with the lint filter out,something can go down where the filter goes and get into the blower but the only way to tell is by getting in there,if you need help send info or go on utube and put in your model and brand name,there's tons of videos out there on taking apart dryers.
Feb 07, 2018 | LG Tromm Electric Dryer
I have a loud sqeek in my GE dryer. I am guessing it is either the drum bearing, or the bearing/pulley on the tensioner. It sounds like its coming from the tensioner, but i cant get to the tensioner to...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 25, 2011 | GE Dryers
DBSR453GB)WW gas ge dryer has a high pitch sqeek when dryer is running
heatman101
Mar 19, 2011 | GE Dryers
My gas dryer in making a sqeeking noise and is not getting hot.
heatman101
iopdf
Mar 17, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My GE DBXR453GAWW is making a loud chirping noise
The rear drum berring is worn causing the chirp.
The motor berring is bad causing the chirp.
Service is needed to prevent fruther damage.
Jan 19, 2010 | Dryers
My GE high capacity dryer has just started making a low whining noise off and on. Any ideas?
sounds to me like the dryer bearing in the very back of the dryer is going out. other possibilities could be the tephlon bearings in the front shroud of the dryer. If the model is one of the older styles 1990 and older i think?
I do apartment maint. so I see this problem from time to time.
Tag
Dec 29, 2009 | GE Dryers
Hi, My LG dryer is making a sqeeking noise when turned on. Pretty loud at first and then sound reduces further in the drying cycle. Any suggestions?
If you can open one of the smalle panels to see inside around the drum- check to see if the belt is rubbing and there is black rubber dust or strings around that area. It is probably one of the bearings or felt gaskets or seals that the drum rides on.
Nov 16, 2009 | LG DLG5932W Gas Dryer
Dryer is not hot. there is no heat coming out
A couple of quick things to look at.
1, Make sure the gas valve is on and there is a gas supply.
2, If the vent duct is not clean or restricted, the vent sensor will not allow the burner to ignite, also make sure the burner exhaust vent is clear. Any restriction of the air inlet or exhaust will cause the burner to not function.
Let me know what you find and we can go from there.
Good luck.
Regards,
Jul 03, 2009 | Dryers
Dryers Logo
188 people viewed this question
Top General Electric Dryers Experts
Tim Whalen
Ned Halaweh
Ned Halaweh
Tyler T
Level 1 Expert
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
