Question about Amana ARB9058CS Bottom Freezer Refrigerator
My Amana bottom freezer model # BB20VSE, serial # 0006289684, mfg # P1321301WS has become increasingly noisy when the compressor(?) turns on. This started over a year ago and now is extremely loud. Thank you for your help. Sandra Forsberg
  • 132 Answers
Ah this is an indication that your condenser has become dirty, or blocked, or the fan motor is not working or the air flow is restricted.
The noise is generated when the compressor cycles off and sudders to a stop
Posted on Mar 25, 2011
New compressor started knocking 1 month after installation
could be a bad unit from day 1,motor loose internally,or it can be moisture in the sealed system
May 12, 2012 | Amana ABL2222FES Stainless Steel Bottom...
Fan is running, but no cold air is coming out into the freezer or fridge. Blown compressor?
Not neccesarily. A compressor uses a relay to start it and an overload to protect it. If either of the components has failed, the compressor will not start. The part number for the relay, overload and run capacitor assembly is 67005560 and can be purchased for under $50 by calling Marcone Appliance Parts at 1-800-482-6022. Keep in mind you may have a locked rotor on the compressor, in which case the part will not repair the problem. Before you do anything, call AMANA at 1-866-616-2664 with your model and serial number ready as the compressor, which is part of the sealed system, may still be under warranty.
Nov 18, 2010 | Amana ARB9059CS Bottom Freezer...
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Amana ARB1917CB bottom freezer refrigerator, not freezing at all has done this before but have always manage to get it working again top & bottom up as high as it can go, but the top doesnt feel that...
YOUR COMPRESSOR MAY HAVE FAILED. USUALLY ABOUT 800 TO REPAIR. THERE MAYBE A FIVE YEAR FULL WARRANTY ON THAT. OR EVEN A 10 PART ONLY WARRANTY. CHECK MODEL AND SERIAL NUMBER HERE TO SEE. http://servicematters.com/warranty/warranty_main.htm
Apr 23, 2010 | Amana ARB1917CSR Bottom Freezer...
Bad capacitor/relay or compressor?
that is most likely a relay. Does the unit get cold while running?
Oct 23, 2009 | Amana ABB1921DE Bottom Freezer...
Noisy Compressor
either the compressor is under charged or it is near breakdown. compressor cost is almost the 1/3 of the freezer cost.
May 08, 2009 | Haier HTE16WAA Top Freezer Refrigerator
ARB2214CB - Condensor is Noisy
It sounds as if the thermal limit on the compressor is cutting off power to the compressor when it gets too hot. There could be 3 reasons for this. One, the compressor is just bad...should be covered under the 5 year sealed sytem warranty (if its less than 5 years old of course) if this is the case. Two, the thermal overload and start relay assembly is bad. They are mounted directly to the compressor (big round black thing) and can be changed for about$14 in parts (unplug the unit before replacing!) Three, the fan that runs in the bottom near the compressor that cools the compressor and condenser is jammed or not rotating for some reason. It should run any time the the compressor is running. If it doesnt, it need replaced or the compressor will do exactly what you are describing. Hope this helps!
Oct 22, 2006 | Amana ARB1905C Bottom Freezer Refrigerator
Amana ARB9058CS Bottom Freezer Refrigerator Logo
235 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
