Question about Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ...
Lexmark X8350 I changed the ink catridges in my printer but it will not work and displying cartridge error, error#1203. consult uer guide
  • 4,041 Answers
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted on Apr 25, 2010
  • Clive
    Clive Apr 25, 2010
    Ok
    or
    All the best Pineworks
It keeps saying cartridge error/ consult user guide 1203 Have replaced the cartridge
Did you replace with Generic Ink or Lexmark Ink Cartridges? See your Printer's Documentation and check to see if your printer will only use Lexmark ink.
Aug 10, 2010 | Lexmark X7170 All-In-One InkJet Printer
Cartridge Error # 1203 when replacing black ink cartridge
It sounds like the printer thinks it is not a genuine ink cartridge. Fit a Lexmark cartridge to cure it.
Jul 16, 2010 | Lexmark X8350 InkJet Printer
Hi my name is Hector,on my 2.5 inch display it say cartridge erro error #1203. I checked my users guide it dosnt say anything about error numbers.
Error 1203 is a very interesting error code. Here is what I found out about error 1203
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a problem and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
or try this other option:
Dell All-in-One Printer Cartridge Error 1203.
I found if you cover a copper contact on the color cartridge the error clears and the cartridge works. Looking from the contact side for the color cartridge 2nd row contact 2 from the left. I found if I use an ohm meter from 2nd to 3rd contact I measure 119 ohms. I believe that is a shorted cartridge. If you bought it New I would get it replaced. I use a SMALL square piece of Scotch tape. I believe this will work on Lexmark printers.
Jan 06, 2010 | Dell 966 All-In-One InkJet Printer
I ordered Lexmark 32 & 33 ink cartridges off ebay (but they are not 'genuine'). I'm getting an error message #1203 - 'Consult your user's guide'. Does my Lexmark X7350 only accept Lexmark brand...
or
Nov 30, 2009 | Lexmark X7350 All-In-One InkJet Printer
Printer is not working new ink
Cartridge World stores have a 100% satisfaction guarantee; they will repair, replace, or refund any cartridge you find unsatisfactory. You need to go to the store you purchased this cartridge from and request a new one.
Sep 29, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Cartridge error
Error 1203 is a very interesting error which normally means that your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges.
Solution:
To reset the error code, disconnect the power cord from the wall. Also remove the power brick from the back of the printer for 60 seconds. Then connect everything again.
Please let me if this information helped.
Please rate me if you are haapy with the solution.
Sep 15, 2009 | Dell 946 All-In-One InkJet Printer
Error 1203 consult user guide, I don't have one. This happen after I change the ink cartridge
This error means that either the ink cartridge is bad, or the copper contacts between the cartridge and the cartridge slot is bad. Try cleaning them with rubbing alchohol and a q-tip, or try a new ink cartridge.
Mar 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark P6250 Printer error 1203 - Consult User Guide
It is a hardware printing problem . Try to clean contacts in printers in cartridge holder by alcogol and elastic rubber. it may become dirty an poor contact. after this you can try this:
Put some layers of the sticky tape on cartridge to improove force of contact.
Mar 06, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Error #1203
Normi, The 1203 error as you suspected deals with the ink cartridge. This is a common problem and Lexmark has a troubleshooting procedure posted on their web site. Here is the link for the web page. http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&emeaframe=&docid=ENUS21870 Hope this solves your problem and please don?t forget to rate this posting.
Jan 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ... Logo
328 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
