Question about Car Audio & Video
My car stereo wont save my favorite stations, why? Please help. Everytime I turn in off everything resets.
  • 591 Answers
You probably forgot to plug a wire that needs power all the time, look in your INSTALLATION MANUAL to locate that wire and plug it to a continuous source of power (even when the car is switched off)...
Hope this helped!!!
Posted on Mar 24, 2011
I have a 2000 mercedes benz e320 and I'm not sure how to save radio stations on it? I've tried holding down the buttons to save but it doesn't work? Any help?
hi you save by setting the station to what ever you want then hold one of the numbers usually 1 to six it will either bleep or flash if its not doing this try disconnecting the battery to reset the stereo then try it again if it still doesn't work there is a problem with the stereo its self good luck
Apr 27, 2015 | 2000 Mercedes-Benz E-Class
Why do my settings reset in aftermarket stereo of my 92 mercury cougar
As well as the normal 12 volt line form the ignition switch, there is a 'permanently on' 12 volt lead, which keeps the clock and memories going even when the ignition is turned off. It sounds like the installer has missed connecting this one.
Aug 28, 2012 | Pioneer Audio Players & Recorders
I have 2 wires coming from the positive battery terminal. The first wire goes underneath the car to the starter. The second wire is separated at what appears to be a fuse link which goes into the drivers...
Hi, this second wire is a permanent live feed for inside the car, the things it runs are things like the stereo all its their for is so the stereo dont lose any stations that you have stored into the memory other than that their isnt much else it runs, maybe the clock, you could check by seeing what isnt working when the key is out, check the clock and stereo, if the stereo works with the key out then it must have its own live feed.
the chances are it wont work and you will lose the preset saved stations.
i hope that has given you some idea of what its for.
please let me know if you need further assistance.
plz can you rate this post as i have pages of unrated posts, thanks
Aug 25, 2010 | 2004 Hyundai Santa Fe
Philips HTS3555 custom settings reset to factory on its own
this happens when the electricity is fully discharged
May 17, 2009 | Philips HTS-3555 System
Kenwood KDC-W312S wont keep the saved channels after car restart
Check the yellow wire connection on your wiring harness... This is the wire that provides continuous power even when the ignition is off. This is how the radio remembers presets/time and such. Every time you turn off the car, the radio "resets" because you dont have the yellow wire connected to an ALWAYS HOT wire.
If you cannot find a hot wire, then you can run a wire from the yellow on the back of your radio directly to the positive terminal on your battery. Dont worry, it doesnt draw enough power to run your battery down.
Most cars have a cigarette lighter or power port somewhere that is always hot. You could always run the yellow wire off of one of these.
Just find a way to get the yellow wire on a hot wire and your stereo will remember the presets.
Mar 29, 2009 | Kenwood M-303USB Shelf System
Cd player will not light up/play cd' s
I have the same problem with my stereo in my '98 Blazer. in the manuel there is instructions on how to reset the stereo. it's a lenghty process, but it normally works until you turn the stereo off.
Mar 27, 2009 | 1999 Chevrolet Blazer
DehP6700 mp restet everytime keys is turned on.
first red is ignition or acc (turns off and on with the key) yellow is constant power (always hot keeps memory) orange is illumination (lights up radio) if vehicle doesnt have a seperate illumination wire connect it to the ignition wire. now process of elimination your ground is correct because it worked with all wires to acc your acc works because u had all them connected to it and it worked your problem is in your yellow or constant/memory i suggest u test it again take piece of wire any old thing long enough will do and run the wire directly from the battery under the hood and just run it outside the car through the window and connect it directly to the yellow wire make sure u have a good connection at the battery on the positive side if u have test light or volt meter test the wire before connecting it to the radio if it works then u know there is a problem with the wire from the vehicle (fuse wrong wire bad wire ) if it doesnt work make sure ground is connected tight and that paint is cleaned of the surface where ground connects and that the yellow wire to the radio is tight in the back of the radio.
Nov 13, 2008 | Car Audio & Video
I bought a car stereo but it wont save presets.
make sure you have the yellow fuse wire hooked up to bat. power (always hot) red wire is your ignition power
Nov 12, 2008 | Pioneer DEH-1600 CD Player
Car radio
On the face of the stereo is a * button. Push this button then use the numbers on the face of the stereo to go directly to that station. Example, my favorite classical station is 90.7. Push the * then 907. This station will appear in display. Then push and hold for about 5 seconds the preset button you would like this station to be. The stereo will momentarily blink to a different station then come back. Station set.
Oct 20, 2008 | Becker Car Audio & Video
Car CD stereo
Either you blew the memory fuse or didn't connect the radio to the proper wire. Check fuses inside and under the hood.
The memory wire to the radio needs 12v all the time. If it's not connected or no power at the lead the radio will reset every time you turn off the car.
Jul 08, 2008 | Car Audio & Video
Car Audio & Video Logo
158 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
