Question about RCA HD52W59 HDTV Projection Television
I have an RCA hd52w59. I just got it today used and I don't have a remote for it. The colors wont converge and I think it is a Convergence Chip Failure from what I have read on here. But one of the ways to fix it involves using the remote. Is there another way to test without the remote?
  • 59 Answers
Chek to see is the setup menu has the word convergence on page.
if not the the problem is an open 0.4 fuse beside the flyback/center one of three in a row.
the fuse blows because the flyback need to be resolderd, cracks on pins.
Posted on Mar 24, 2011
I have a r56wh78 rca tv that the colors wont converge, can it be fixed
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 21, 2010 | RCA HD52W59 HDTV Projection Television
My RCA HD52W59 HDTV Television has double vision and red, green and blue colors separated like a spectrum in stead of all the colors blending together to make one uniform picture. What can I do?
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 09, 2010 | RCA HD52W59 HDTV Projection Television
My rca hd52w59 tv looks like its in 3-d. auto covegnence used to solve the problem most of the time but now it does nothing. pic is constantly looks like 3-d now. the colors r all not right. i get it close...
Hi
Thanks for using FixYa. You’ll need to change the convergence chips which are located behind the black heat sink; you can see once you open the back off the TV. You can buy the convergence chips from this link; also if you want you can buy repair kit which comes with complete installation and parts. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | RCA HD52W59 HDTV Projection Television
Hi I have a rca hd52w59. the top half of the
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 24, 2010 | RCA HD52W59 HDTV Projection Television
My RCA HD52W59 HDTV has a convergence problem. It
On your Deflection Board it is the bottom left hand side board has FBT flyback transfomer on it Blowed Fuse FL231 it will be on right hand side of FBT there is 3 of them in a roll small brown rectrangler looking caps but they are fuses ir will be the one in the Middle Call PartStore.com 1-866-925-7278
Dec 31, 2009 | RCA HD52W59 HDTV Projection Television
Picture is bent. color is a bit fuzzy and 3 lines
Ur convergence it dead,know how to solder?Buy a convergence kit use what in that kit.Tries websites Tv Repair World.com,Ebay.com.
Oct 15, 2009 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 3d screen colors are seroperated no convergence
step by step instructions are avalable in the tips and tricks section of this website.
May 29, 2009 | RCA HD52W59 HDTV Projection Television
HD52W59 HDTV
Sounds like the fl231. First question? In the setup menu do you have convergence option? if not this is an indication of the special fuse called fl231
Sep 16, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 Wavy lines
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
120 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
