Question about Dryers
My dryer has power, i can hear it but the motor is not powering on
  • 822 Answers
There is a silver can shaped capacitor near the motor, mite need replacing.
easiest way to see if its the cap............ is to have the dryer lid off and...........
very carfully............veryyyy carfully........push the drum round with your hand........
if its the cap.the drum will turn..................but i must stress you have to be careful.......
cheers
Posted on Mar 24, 2011
    Champion:
  • 239 Answers
The most likely faulty part is the thermal fuse. You don't specify brand, but I suspect you have a Whirlpool or Kenmore product. Remove the back and locate the white, plastic rectangular fuse with bluw wires going to it. With the dryer unplugged, tape those wires to gether and see if it starts. If it does, replace the fuse.
Kelly
Maytag epic dryer
Without seeing dryer and checking it , best guess could be main control board problem
Dec 08, 2013 | Dryers
Dryer powers up but the drum doesnt turn
The drive belt is either broken or the belt tensioner spring is broken.
Feb 03, 2018 | Samsung DV448AGE Gas Dryer
Dryer has no power will not turn on
Is door shut good ? Check door switch push it in and see if you can hear it click. Check power at outlet then where it goes into the dryer. Check start switch and voltage coming out of the timer. Check voltage to motor. If voltage to motor you will need a motor.
Nov 11, 2013 | Whirlpool LER5636P Electric Dryer
Dryer has power. control lights working. when you press the start button the only sound is a humming noise. will not start.
Check your drive belt which is located around the outside of the drum. The "hummmm" you hear sounds like the motor running. Normaly this motor provides the power to the belt which surrounds the outer surface of the drum (where u put the cloths)........ the belt wraps around the outside of the drum, then around a small pully mounted on the shaft of an electrical motor normally located just below the drum on the inside of the outer enclosure. This motor will be mounted to the the dryer's frame by a mounting plate. This motor mounting plate will pivot (like a hinge)..... it will also have an extension spring hooked to it which provides tension to the drive belt when properly looped around the pulley on the drive motor. When the belt breaks or snaps....... the drum stops spinning..... however the drive motor still runs. Thats the noise you hear! Diss-assemble outer sheet metal providing access to drive belt and replace with correct belt recommended for your model dryer. Caution should be used during repair........ ALWAYS UNPLUG POWER CORD PRIOR TO SERVICING ALL/ANY APPLIANCE's !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
May 14, 2011 | Frigidaire AEQ8000FG Dryer
Dryer has power. When the start switch is turned,
Sounds like start winding inside the motor, or a start switch attached to the motor itself.
Jun 22, 2010 | Frigidaire GLEQ642A Electric Dryer
Power going to dryer you can hear a noise when pressing start but not starting
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 21, 2010 | Hotpoint Ariston ASL 75 CXS NA Electric...
Dryer will not turn
IF YOU STARTY THE DRYER AND HEAR THE MOTOR RUNNING THE BELT HAS BROKEN
Aug 11, 2009 | Dryers
Dryer wont turn on but it gets power
If you can hear the motor turning but the drum is not turning its the belt. Don't hear the motor its the door safty switch.
Jul 07, 2009 | Dryers
Kenmore heavy duty plus
Sure. The likely problem is a broken belt. Do you hear the motor? If not, it could be the motor. Pull the back off the unit...with the power off and have a look.
Dec 21, 2007 | Roper RES7646KQ Electric Dryer
Lg td-c70045e electric dryer power on but not turning
I had the same problem. Replaced the capacitor and now all is ok. Dryer is working 100%. If you hear a humming sound from the motor then it means the capcitor is faulty and does not start the motor properly.
Oct 24, 2007 | Dryers
Dryers Logo
Top Dryers Experts
