Question about Hoover Windtunnel Supreme U5280-900 Upright Vacuum
I need the part number for the wheel on the motor of this vacume u5280-940
  • 436 Answers
Go to this site for parts breakdown. to see the up close veiw, simply move your cursor onto the picture.
http://www.searspartsdirect.com/partsdirect/part-model/Hoover-Parts/Vacuum-Parts/Model-U5280-900/0517/0645000
good luck .
Posted on Mar 24, 2011
Miele vacum motor dead
would need more info to really isolate problem but you either need new cord reel, speed control board, or new motor. maybe all three. either way a make and model number would help
Apr 02, 2013 | Miele Vacuums
Nilfisk vacume bearings
Hi There, If you could provide the model number of the machine that would help. However as a general rule if it is the motor bearings you are after then normally you replace the entire motor. If it is the roller brush you are needing bearings for you can get them from any bearing supplies store. If you are looking for any nilfisk parts in Australia then vacuumspot is the go.
May 27, 2012 | Vacuums
My vacum keeps sutting itsself off after a few mins of use. I need to vacum the whole house and dont have tinme for it to cool down every 10 mins
Something is plugged. What you describe sounds like the motors' thermal limiter is opening the circuit to prevent the motor from overheating. You need to open and verify that evey air passageway is clear and the unit has good air flow. I bet you find a blockage, and with one, cleaning ability would be severly diminshed.
Nov 19, 2010 | Dyson DC31 Animal Bagless Handheld...
My vacum roller brush dosenot work
The most common failure there is the drive belt from the motor to the brushes has failed. Consult your local vacuum store for a replacement. Normally they are fairly easy to change. Check and see if the brush is free wheeling or needs a push to get it to turn. If the belt is broken or worn out the brushes will turn freely.
Mar 30, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
POWERMATE HEAD DOESNT SEEM TO HAVE GOOD SUCTION AND IS LOUD
suction wise have you checked the internal pipes on your vacum as for the load noise if it is quite a load noise a humming noise it is ure motor so not worth fixing motors r pricey for a vacum
Feb 03, 2010 | Kenmore Vacuums
When i conect the vacum part to maun system it
There is a motor in the power head that could be out or the receptacle, electric cord on power unit or loose wire in power head.
Oct 14, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Self propel feature is not functioning. have to push the vacum cleaner
Remove the bottom plate and look for broken or loose drive belt to the wheels. Check the wheels for being bound-up with thread, hair and other debris. Make sure that the motor for self-propel runs when turned on.
Aug 15, 2009 | Vacuums
I can't figure out how to change the belt on my hoover bagless Sprint upright. Please help.
1 set up vacume with bottom facing you , making it easy to deal with.
2 remove the 4 screws holding base plate on and carefully remove the base plate, on mine there is a small catch that must be released.
3the belt compartment is on the right, remove the old belt, it's about 1 and 1/4 wide.
4 You have to put the belt on the stainless steel motor spindle first, then work the belt over the plastic drive wheel, and spin it around a few time to ensure it's running on track ok.
5 Replace the base plate , click in the self catching clip last.
6 Replace the four screws and test the vacume.
Oct 23, 2008 | Hoover Vacuums
Fantom twister 500DX
Take off the bottom plate (where you would access the belt). Put the wheel
back on, put the screw back in the wheel and looking from the underside
of the vacuum you can see the screw. You need a bolt and preferably a
lock washer and that should hold it for you.
Jun 16, 2008 | Fantom Vacums FM760 Twister 500DX Bagless...
User manual required
if you are in the US you need to call 800-437-7170 to get a manual - i'm not sure it will help in enough internal detail to help you get things back together, but the same number is for Kirby technical support and they may talk you through it. If you want to try online then; http://www.kirby.com/CustomerService/ContactUs/tabid/73/Default.aspx if they don't, then please take a good selection of photos of what you have, and post them back here or try and call on a live chat and we can see what we can do to help. Hope this helps you out :)
Apr 21, 2007 | Kirby G5 Bagged Upright Vacuum
Hoover Windtunnel Supreme U5280-900 Upright Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
