Question about Refrigerators
Where is locate the defrost sensor? - Refrigerators
  • 1,998 Answers
Defrost thermostat is located behind the panel of the freezer along with the defrost heater the heater goes around the bottom of the condensor the thermostat is usually located on one of the copper lines that comes off the condensor the deforst timer is located on the ceiling of the refrigerator if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Posted on Mar 24, 2011
  • 42 Answers
It is usually on the evaporator. Post a comment with the model number and brand, and I can tell you more. some refrigerators don't have a sensor for the defrost. They would have a clock style timer that tells it when to defrost.
DANBY REFRIGERATOR MODEL NUMBER DFF092C1BSLDB WHERE IS THE DEFROST SENSOR LOCATED
The defrost thermostat is going to be behind the rear panel in the freezer and on top of the evaporator there's no picture but you can talk to Danby parts dealers I'm posting a link below to the page that is related to your refrigerator and its parts it come in helpful
Danby DFF092C1WDB Refrigerator 9 20 Cu Ft
Appliance 911 Sea Breeze
If you have any other questions please let me know I'll try to answer them for you. The people that sell the parts call this a defrost protector just for your information
Sep 09, 2016 | Danby Refrigerators
Our Viking professional vcbb363rss freezer is icing up because auto defrost seems to have quit, including the freezer fan. Everyone seems to agree that it's a control board. Do where are they located?
More probable is the the defrost sensor. It is located in the evaporator section in the freezer section of the refrigerator. It will be clamped on the refrigerant return line to the compressor. The sensor closes on temperature decrease below 5 degrees and opens during the normal defrost cycle at least 2 times a day. If the sensor does not close the refrigerator stops defrosting and ice will accumulate as yours seems to be doing. Take your model number to searspartsdirect.com and find the evaporator or controls section and find your sensor. You may need to make a splice to install your new sensor to the electrical wire. some just have push on pull off connections and other have to be spliced. You may have to use a hot air gun like a hair dryer to defrost the evaporator panel to come loose to remove panel. the panels typically have several screws holding them in place and are generally easy to removel. The side normally have gaskets that need to be removed carefully with damage to be reinstalled after sensor replacement.
Hope this helps.
Oct 22, 2014 | Refrigerators
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
Freezer not auto-defrosting; replaced defrosting coils. What controls them?
Hi welcome to fix-ya. The defrost is started when white sensor located top of coil left side. That tell the motherboard to defrost. When done the same sensor shuts down defrost. The defrost termintor that is wired in line with heater is only for safety. I hope this helps.
Sep 18, 2011 | GE GSS20DBPWW / GSS20DBPCC Side by Side...
My freezer is freezing great, the fridge is not cold at all! Just moved fridge into my house yesterday, bought on Craigs list
the freezer actually cools the fridge via a fan usually located in the "ceiling" of the fridge. make sure this is working and check yur temp contols make sur they are adjusted right
Aug 16, 2009 | Frigidaire FRT18G4A Top Freezer...
Need photo of freezer defrost sensor, switch or thermostat
Before replacing all of the components mentioned above, locate your defrost heater and check for continuity with an ohm meter,this will ensure no breaks in heater coil
Jun 29, 2009 | Viking Professional VCBB363SS Stainless...
Locate defrost sensor
Remove all of the racks and drawer from the freezer, take the back wall off from the inside of the freezer, defrost limiter/thermostat will be attached to the evaporator near the top, it will be a metal cylinder with two wires coming out of it. It opens on warm and closes on cold
Jun 17, 2009 | GE GBS22HCP Bottom Freezer Refrigerator
Defrost board contacts in relay chater and do not let defrost
is sensor at proper location? try turning sensor ? Ohm sensor as you turn it.
Jan 14, 2009 | Goodman CLQ36AR49 Air Conditioner
Defrost controle
caint do it you can read the defrost circuit easyier by going into the freezer and ohming out the heater, btw the stat that is on the evaperator coil will read contunity up to 145 f it is not a bi-metal it is a over temp sensor
if you have a defrost issue check the heater of ok then go to the sensor also located on the evap coil
if it reads contunity then mother board located on the back of the ref
Apr 15, 2008 | GE PSW23PSRSS Side by Side Refrigerator
Freezer won't stay defrosted
defrost heater is behind the freezer rear panel along with the defrost sensor,check doors are sealing correctly, usual fault on this unit isdefrost sensor
Sep 02, 2007 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
