Question about Whirlpool LGR8648L Gas Dryer
HI my whirlpool gas dryer will not dry. Sometimes it will work and sometimes it doesn't. As i turn it on, it will glow and next comes the flame. But after a little while the flame will shut off. And also sometimes when i turn on the dryer it will glow and then there would be no flames. I noticed that i could smell gas around the dryer too. Could there be a problem with the dryer? should i replace it as a whole or just a simple part will do?
    Champion:
  • 239 Answers
The gas coils are weak and will need to be replaced.
Kelly
Posted on Mar 24, 2011
Whirlpool dryer heating sporadically?
Remove the lower front panel and turn dryer on. The ignitor should glow bright orange first. After Ignitor glows brightly the next thing will be the flame lighting as the gas valve opens with a click. All this should happen within about a minute or so.
If flame comes on but goes off quickly It's likely one of the Gas valve coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The coils are purchased as a kit.
If ignitor goes off and no flame comes on the coil kit is likely needed because one coil is fully broken inside its case. If flame goes on but shuts off shortly the problem is as described above and the kit is needed.
There is a flame safety assembly on the can above the burner. If the airflow is poor. the flame tip may activate that safety and turn the flame off. Or the flame switch may be open and not allow the flame to come on at all.
The Flame switch can be tested for continuity with an ohmeter but the valves may ONLY show bad with power applied and can not be tested with a meter as they will test good.. Good Luck
Nov 18, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
THE FIRST TIME THE DRYER STOPPED HEATING THE CLOTHES THE FLAME DIDNT KICK ON AT ALL. SO WE REPLACED THE HEATING FUSE AND IT WORKED FINE FOR 8 MONTHS. NOW THE HEAT COMES ON BUT DOESNT STAY ON LONG ENOUGH TO...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 26, 2011 | Whirlpool LGR4634J Gas Dryer
Whirlpool lgn2000LG0.... flame wont ignite.. glow stem glows..
heatman101
Jan 04, 2011 | Whirlpool LGN2000LWH Gas Dryer
Why does the flame only come on once in awhile
heatman101
Dec 07, 2010 | Whirlpool LEB6200 Electric Dryer
Gas dryer starts out ok. When it needs more temp to keep drying, the glow plug turns on and waits for the lp gas to show up and nothing happens. My quess, 1. solenoid valve malfunctions 2. no flame...
heatman101
Sep 03, 2010 | Amana NDG5800 Gas Dryer
May Tag Gas Dryer Model MDG3000AWW - Dry works but no heat, more dry/ less dry lights flashing. Whats wrong? How do I get heat again?
it is either your glow coil or it is your ignitor
open the door and remove the four screws
take the front panel off.
leave the door attached so you can test the dryer
be very careful not to touch any wires while you are doing this
now close the door and turn the dryer on
does the ignitor turn on?
if yes that is good
does the ignitor glow and no flame?
sometimes it will take a minute to show it's problem
if the ignitor glows and no flame replace your ignitor coils
make sure to turn the power off when replaceing the coils
Aug 24, 2010 | Maytag Dryers
I have a a Whirlpool LGB6000KQ1 Gas Dryer. Sometimes the heat comes on, sometimes it does not. Could it be the thermostat or something else?
it appears as if your unit has a small plastic plug/access hole cover below the left corner of the dryer door. if you remove that you should be able to look within the dryers burner area and observe what might be happening..
if when you turn the dryer to a normal timed cycle, on high heat and start the unit, shortly after the dryer begins running you should be able to observe the glow ignitor glowing through that access hole, and shortly after that hear a click and flames appear, if is not glowing then there are probably thermal fuses blown out on the backside of your unit, or the ignitor is bad.
if however it does glow, and maybe even fire up once then all the safetys mentioned b4 are good.. now sit there and watch your ignitor/burner assembly.. the flame will cycle on and off depending on the dryers internal temperatures, but the main thing to look for is whether the ignitor glows, then fails to click then produce flames, if that be the case the gas valve coils are bad and need to be replaced part # is 279834 - M STYLE COIL KIT
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool LGB6000KQ Gas Dryer
Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 31, 2009 | Whirlpool LGB6300 Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Whirlpool LGR8648L Gas Dryer Logo
77 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
