Question about Onkyo TX-SR606 Receiver
The remote control does not turn the receiver on or off or does it change any of the functions and also the volume control on the remote does not change the volume
  • 31 Answers
Have you tried changing the battery in the remote?
Posted on Mar 24, 2011
My New Xfinity XR 5 remote codes will not turn my receiver on & off . OOnly control Volume & Mute.
You either have the wrong remote code or it may be a case where-as the remote will not properly operate "all" functions. Wrong programming "codes" with universal remote controls often operate some but not ALL functions and some remotes are unable to duplicate every function. If all else fails, you use two remotes with one for Xfinity and one that came with your stereo.
Mar 28, 2015 | Yamaha RX-V665 Receiver
My universal remote will turn on my audio tuner but not change the volume
Universal remotes do not always control all functions of a connected device
Jan 17, 2013 | Arris DCT6200 DTV Receiver
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
My dish network remote control powers the receiver (turns it on and off), but it won't change channels or adjust the volume. why?
I hope that your remote is working now, but if it is not, or you have any other issues in the future, here are some steps to help out. The link below will walk you through programming both your remote to the volume and the receiver. Sometimes the remote will not work certain functions if the batteries are starting to ware out, also if there is anything blocking the dish, the remote doesn't work as well. So you will want to make sure that there is nothing in front of the receiver, such as glass, and that your batteries are less than 60 days old.
Steps 1-5 are for the receiver, and 6 on are for the tv! I hope this helps!!! http://www.dishnetwork.com/SupportSection/remote-setup
Becki Barned
DISH Network Customer Service
Jul 30, 2010 | DISH Network IR Remote Control
I have a Yamaha RX V665 and I am unable to change the volume
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jun 07, 2010 | Yamaha RX-V663 Receiver
Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Aug 07, 2009 | Denon AVR588 Receiver
Remote Volume Control Not Working
MEtten,
Flip the top cover, just above the "AV MENU" there is a round boll kind of switch, it has to be pressed when you want to function top cover button, so may be it is warn out or the nob has been broken. if you press that switch with pen nob it will function...
It is bad design...
Surendra
Jan 05, 2008 | Sony STR-DA3ES Receiver
Yamaha RX-V793 flashing light on volume control and no volume
Per Yamaha support page: The volume light on my Yamaha AV receiver is flashing, what does this mean ? The "MUTE" function on your remote control has been activated. The reason that you can still hear a very low sound is that the muting circuit within your stereo is not a full mute, but rather a -20dB mute. To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office. You may reach them by dialing (714) 522-9888 from 8 am to 3 p.m. Pacific Time, Monday through Friday. If you have any other questions, please contact our customer service department by dialing (800) 292-2982 Monday through Friday from 8:00 a.m. to 4:00 p.m.
Sep 03, 2006 | Yamaha RX-V793
Onkyo TX-SR606 Receiver Logo
125 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
