Question about Kenmore Dryers
Kenmore dryer model 110.86572500 when drying continues to run at the 20 min. mark won't shut off
  • 96 Answers
There is a ceramic resister mounted inside the console beside the timer that needs to be replaced
Posted on Mar 24, 2011
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Dryer runs for about 20 min. then shuts off will start after it cools down and run again for another 20 min.
The only thing that can be is a bad motor. Both the run and start windings are going at the same time. Start windings are not dropping out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 19, 2011 | Kenmore 66832 Dryer
Cleaned vents, dryer gets very hot, shuts off w/o drying clothes
Sounds like a faulty operating thermostat. Only way is to test on a electric griddle that you can set the temperature to 150 deg and measure with a ohm meter.
May 26, 2009 | Kenmore Dryers
Dryer only shuts off and restarts during cycle
Get a new timer. It is not that expensive and the wiring is fairly simple.
Jan 14, 2009 | Dryers
Kenmore Dryer 90 Series shutting down. overheat?
Your motor is very likely overheating and needs replacement. A simple test is the motor will be so hot you cannot even touch it. Hope this helps!
Jan 05, 2009 | Kenmore 62602 Electric Dryer
Kenmore 110 gas clothes dryer heats for 20 min then needs to rest for 20 mins before heating again
Cause 1Thermal Fuse
The thermal fuse is a safety device designed to protect the dryer from overheating. The fuse is located on the blower housing or at the dryer's heat source such as the heating element on electric dryers or at the burner on gas models. The fuse should be closed for continuity meaning it has a continuous electrical path through it when good. If overheated the fuse will have no continuity meaning the electrical path is broken and the fuse has blown. A multimeter can be used to test it for continuity. Be aware that a blown thermal fuse is an indication of a restricted exhaust vent from the dryer to the outside. Always check the dryer venting when replacing a blown thermal fuse.
Parts Cause 2Gas Valve Solenoid
Gas dryers have two or more gas valve solenoid coils. The gas valve solenoids open the gas valve ports to allow gas to flow into the burner assembly. If a gas valve solenoid fails, the dryer won't heat. To determine if one or more of the gas valve solenoids has failed, check the igniter. If the igniter glows and goes out but does not ignite the gas, the gas valve solenoid is defective. If one or more of the gas valve coils are defective, we recommend that you replace them as a set.
Parts Cause 3Igniter
The igniter uses heat to ignite the gas in the burner assembly. If the igniter is not working, the gas will not ignite, preventing the dryer from heating. To determine if the igniter has burned out, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Feb 16, 2018 | Dryers
Dryers Logo
77 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
