Question about Williams (5009622) Ceramic Gas Wall Mounted Panel Heater
Can anyone fix the ticking and banging expansion noise when first turned on and after it goes off?
    Brigadier General:
  • 4,736 Answers
Not really much you can do about it. With time it stresses itself out. However, if you're using the the blower, it should continue automatically to run, until the heater cools down some. That should ease some of the noise from metal expansion. The other thing to consider is whether the flame height is to tall? This would cause it heat up more than it should. Also, make sure nothing is obstructing the intake air flow (air that's taken in from the house, heated and sent back out).
Posted on Mar 24, 2011
How can i turn off key tones?
A hammer will work... just bang the phone a few times and ticking noises will disappear!
Apr 14, 2015 | Cell Phones
Clunking/ticking noise during acceleration in 3rd and 4th gears
This sounds on the base of it to be pre ignition, if so the moment you take the foot off the gas it goes? The cure is to retard the ignition timing slightly, have you recently changed your octane of fuel? this will also cause this?
The noise is caused by the expansion of the compressed gases expanding before the piston reaches top dead centre causing the piston to \'rattle\' left unchecked will cause permanent damage and engine failure
Jan 16, 2013 | 2008 Volkswagen Rabbit
Won't stop ticking!!!! Why??
The noise could be from the expansion and contraction of the metal from heating up and cooling down. You could try loosen the mounting screws of the unit slightly to see if that helps.
Dec 14, 2012 | Williams (5009622) Ceramic Gas Wall...
Banging noise when hot water is turned off
plenty of water pipes particularly in older houses where pipes may not be fastened tightly or at all to the frame of the house suffer from what plumbers refer to as waterhammer. This can be fixed by installing a small device inline from your local plumbing shop. It can also often be solved ( I have found) by fastening you water pipes at closer intivals/more securely to your house frame. Hope this helps. Mine stopped doing it once the pipes were locked in place.
May 11, 2012 | Rinnai Water Heaters
The engine is an E 36 and the is a loud ticking noise coming from the right side front of the engine where the alum cover is in the front it goes away at some higher rpm's but is there on startup and idle...
Not sure of the motor. Assume you are talking about a BMW E36 (325, 358, 318 etc.) What you are probably describing is a valve tap. Sort of a ticking sound not a bang bang bang right? If this is the case you need to have your valves adjusted. Not really a job for a weekend warrior but a search on the car forums may let you decide if this is a job you want to tackle.
May 20, 2010 | Cars & Trucks
After use, while its refilling, my Rheem hot water heater makes a banging sound inside. Anyone have this issue?
I suspect the noise is being caused by expanding metal groaning or 'popping' due to the expansion. We have a metal roof on our home and heating and cooling are always accompanied by similar noises that are inaudible inside the house but catches our attention if we are on the porch.
Nov 04, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Tappet clicks come & go
the go away because of heat expansion-
check for low oil and then have the tappets adjusted
Apr 04, 2009 | 2004 Mitsubishi Lancer Evolution
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Williams (5009622) Ceramic Gas Wall Mounted Panel Heater Logo
481 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
vance jones
Superior Maintenance
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
