Question about Alpine CDA-7839
I have an alpine cda 7839 radio in my car. I have no manual and cannot figure out how to change the minutes on the clock. I figured out the hour.
TekTrax
SOURCE: Alpine cd redeiver CDA 7837
Just a guess, I’d say who ever installed it didn’t hook up the connector behind it. But lets say they did. In most cases, the radio’s connector bundle will have a fuse. It’s a good idea to check your car’s fusebox first to see if any fuses are blown there. In either case, if you replace a blown fuse with "the right value", and it blows again, have a tech check it out. Note that if you try to get to the rear of the unit, do a little research into how the radio is accessed through the dashboard. Most car radios aren’t quickies to get at and some folks can do damage trying to get at it, but if you methodically take logical steps, you should be able to pull the radio, check the connectors, locate the fuse if it has one. Of course, there may be a wiring incompatibility, meaning, the OEM radio had it’s own specific wiring harness, the Alpine was installed, but someone didn’t get the adapter harness to fit the car. Who knows. Good luck. TekTrax
Posted on Nov 03, 2007
SOURCE: setting time on clock
alpine model cda-9811 cd receiver mp3/wma please help. I don't know how to set my clock and how to set the speaker balance. Could you please help me? ty Ronnie
Posted on Sep 19, 2008
SOURCE: don't know how to display clock on Alpine CDA9813
i think the clock is on the disp button in the top left
Posted on Mar 02, 2009
SOURCE: purchased car with alpine cda-9885 in it.I need a
http://vault.alpine-usa.com/products/documents/CDA-9885%20OM.PDF
Posted on Apr 02, 2009
SOURCE: can't set clock in car I bought
set clock on my alpine CDE-9874
CD reciever
Posted on Nov 05, 2009
Alpine Cd Reciever MP3 WMA CDE-9845 EM How to set Clock
Quickly push the knob in again to get to the minutes then rotate the knob as before to set the minutes. press the knob again to confirm your setting.
Jul 14, 2013 | Alpine CDA-7894 CD Player
Set clock on a alpine cda-9805. I can change hr not min
Heree is how to set the time on the radio.
1 In the Clock priority mode, press and hold the DISP/
TITLE button for at least 3 seconds while the time is
displayed. The time indication will blink.
2 Turn the Rotary encoder to adjust the hours while the
time indication is blinking.
3 When the hour has been adjusted, press the Rotary
encoder.
4 Turn the Rotary encoder to adjust the minutes while
the time indication is blinking. The time is automatically
set 5 seconds after the minute adjustment. The time
can also be manually set by pressing the Rotary
encoder
If you need the manual is on the link below page 6 tells you how.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDA9805.PDF
Good Luck
Nov 06, 2010 | Alpine CDA-9805 CD Player
How do I change the time on this model?
if you go to this link
http://www.retrevo.com/support/Alpine-CDA-9885-Car-Receivers-manual/id/1060dj489/t/2/
here you be able to download the manual all the functions and features of your radio. If this helps please label this as a FIXYA
Jun 18, 2010 | Alpine CDA-9885 CD Player
How do you change the time on the clock? Don't
This is from Page 7 of the manual available on Alpine's site:
moz-screenshot-1.pnghttp://vault.alpine-usa.com/products/documents/OM_CDA-9884.PDF
Setting the Time
1. Press and hold F/SETUP for at least 2 seconds to activate the SETUP selection mode.
2. Turn the Rotary Encoder to select CLOCK ADJUST,
and then press "magnifying glass"/ENT
3. Turn the Rotary Encoder to set hour.
4. Press "magnifying glass"/ENT
5. Repeat steps 3 and 4 above to set minute.
6. Press and hold F/SETUP for at least 2 seconds to return to normal mode.
I hope that helps.
May 21, 2010 | Alpine CDA-9885 CD Player
I cannot figure out how to change the clock! Help please.
From the manual...
Setting Time
1 In the Clock priority mode, press and hold TITLE for at least 2 seconds while the time is displayed. The time indication will blink.
2 Turn the Rotary encoder to adjust the hours while the time indication is blinking.
3 When the hour has been adjusted, press the Rotary encoder.
4 Turn the Rotary encoder to adjust the minutes while the time indication is blinking. The time is automatically set 5 seconds after the minute adjustment. The time can also be manually set by pressing the Rotary encoder.
• To synchronize the clock to another clock/watch or radio time announcement, press and hold the Rotary encoder for at least 2 seconds after setting the “hour.” Minutes will reset to 00. If the display shows over “30” minutes when you do this, the time will advance one hour.
Jan 12, 2010 | Alpine CDA-9847 CD Player
Is there a cable that will hook up the cda 7839 to
No, the CHMS600 is not AI-Net compatible and thus your deck will not control it.
Aug 23, 2009 | Car Audio & Video
Adjust clock on alpine cda-9884
Look on the bottom part of your faceplate and there will be a button with a (F) on it and you hold it then you will figure the rest out. Or just look in your owners manual.
Jan 31, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Setting time on clock
Press "Title" until time is displayed. Then press and hold "Title" for a few seconds until time is displayed. Turn the silver knob to change the hour, after hour is set, press the silver knob to activate minutes. Turn sliver knob to change minutes. Press silver knob to end.
Feb 15, 2008 | Alpine CDA-9811 CD Player
Don't know how to display clock on Alpine CDA9813
Feb 15, 2008 | Alpine CDA9812RB CD Player
Alpine CDA-7839 Logo
52 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
