Sounds like thermostat is bad... Vulcan also recommends on replacing the high limit as well.
If you have further questions, call Vulcan directly and they will direct you to a dealer that sells their parts... Their number is 502-778-2791. If I can help in any other way, call me at 888-542-5959, Restaurant Equipment Outlet, Cincinnati, OH and our website is www.restaurantequipmentinc.com
Don't know if the pilot has been cleaned or the thermopile has been changed. The pilot being lit can be good to keep valve open but not strong if enough to open main burner. If after checking all the above, make sure you have gas flow from the valve, if so replace thermostat.
Does this fryer plug up to power of not?If it don't ,then thehi limit is out,need to reset it and try lightning it back.You will need to hold if for a minute.At this time if it don't stay lite,then replace the pilot thremcouplen.
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Your question is posted under vulcan fryers but the comment refers to a grill. Either way, I think your problem is gas pressure and/or supply related. You may need a new regulator, you valve may not be open all the way or any quick couplings you may have are not coupled completely or are faulty. What is happening is there is enough pressure to keep the pilot going, but when the larger route for the burner gas is opened the gas is quickly used up without proper resupply. A regulator installed backwards can have this same effect. Hope this helps
The thermopile is bad.You can contact your local hobart service center for the part number.Its a cheap part and easy to put on,any questions let me know.
