Question about Lexmark X75 All-In-One InkJet Printer
Print Problem The scan and print works okay, whoever when I try to print from the computer or a saved document from my computer, it seems to leave lines as if something needs cleaning. Both Ink cartridges are new black and color.
Free needed software for lexmark x75
Posted on Aug 22, 2008
Printing from computer gives error message but troubleshoot efforts have not worked.
Hi,It seems that its a software issue only. dnt worry I will help to come out of it. I believe you are using this printer wirelesly, there forth you need to insert the CD and go under computers>> right click on the drive>> explore>> util >> CCC >> then do uninstall l3>> restart the computer and reinstall it. it will work wish you all the luck :D.
Jan 05, 2012 | HP Officejet 6500 Wireless All-in-One...
I'm using a wireless canon pixma mx350 but am unable to print web pages, in particular from a HSBC site. As soon as I click print, the printer disappears!
1.Try doing Ctrl+S and saving the webpage to your computer first. Then open the saved webpage and try printing from there. 2. If that doesn't work, try right clicking in the portion of the page you wish to print, and doing "Print This Frame". 3. If that is not an option, try using Ctrl+P instead of clicking on the print button. This should bring up the print dialog. 4. Otherwise, try using Ctrl+A to select everything, Ctrl+C to copy it, open a new Word document and use Ctrl+V to paste it. Then try printing the Word document.
Good luck! And PLEASE leave me positive feedback!
Jul 27, 2011 | Canon PIXMA MX350 Wireless All-in-One...
Put scanned document on my computer to print afterwards if necessary and read on my computer
I am unclear on your problem but in general..you use the scanning software that came with the scanner scan the document and save the scanned file to your computer as a pdf file for documents or tiff or jpg for photos, (you set the type of file you want to save with the software options)
To print afterwards open the pdf with acrobat and print it
Did that answer your question?.
Mar 07, 2011 | HP Scanjet 5590 Flatbed Scanner
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
My hp deskjet printer can not copy or scan
Error message?
Just put something on the scanner glass and press the print button in the printer itself, leave the computer alone.
Did it work? if so... there's something wrong with the HP software, re-install.
That machine takes copies without the computer on, so, it should work.
Sep 12, 2009 | HP DeskJet F380 All-In-One Printer
Seems to do everything but scan to computer it will scan and print a photo but when I try to scan to computer it prompts, "place document on planten glass" well the document is on the planted glass but it...
Click Start, choose printers and faxes, choose scanners and cameras, right click WIA Canon MP970, click properties, choose events tab, choose select an event, scroll to "attach to email".
Jul 26, 2009 | Canon MP970 Photo All-In-One InkJet...
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak esp 5 won't scan to computer
Here is the solution I found on the Kodak ESP 5 Support Center web page. Hope it helps or else maybe just visit the web page and browse it to see if you can find the solution to your specific problem.
Question : How do I scan from my all-in-one printer using MICROSOFT WINDOWS Imaging Acquisition (WIA) Drivers on a computer running WINDOWS VISTA Operating System? Answer : For computers running WINDOWS VISTA Operating System:
  1. Click Start > Programs/All Programs, and select Windows Photo Gallery.
  2. Click Scan at the bottom of the Windows Photo Gallery window, then click New Scan at the top of the window.
  3. Select KODAK ???? AiO (where ???? is the model number) from the Select Device window, then click OK.
  4. Click Preview and make whatever adjustments needed to achieve the desired scan.
  5. When you have made the desired adjustments, click Scan.
    During scanning, the progress is displayed.
    When the scan is complete, the file is displayed in the Windows Fax and Scan window, along with a preview of the file.
  6. Click Save as... to save the file, or click the Print icon to print the file from the Windows Fax and Scan application.
Feb 28, 2009 | Kodak ESP 5 Printer
After installing the HP PhotosmartC5280 All in one printer we can get it to scan and print from new documents. Yet, when trying to print from a saved file we receive the message that we do not have enough...
Try to delete unnecessary files on your computer, coz your computer is low in memory. open up your printer if theres a pending document then try to clean or empty it. boot your pc. Then try to print your document.
Nov 29, 2008 | HP Computers & Internet
Lexmark X75 All-In-One InkJet Printer Logo
49 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
