Question about Fisher and Paykel Refrigerators
I have a Fisher & Paykel Fridge Model E521T Serial # BSQ725303 The fridge is still working but it is making a groaning noise like the compressor is cutting in & out. Also the green & red lights inside are flashing all the time If I open the door the noise stops. When I shut the door the noise returns in about 5secs Any assistance will be appreciated Thank you Peter Smith
  • 132 Answers
Ah the evaporator fan is the noise.
Either the fan is hitting on built up ice or the bearings in the motor are worn.
If it is ice then you have a defrost problem and you will need a technician to help you there.
If it is the bearings you will need a new fan motor. Again a technician can help you
Posted on Mar 25, 2011
Freezer capacity fisher & paykel fridge model E521T
Type Freezer on top Fridge size Large (451-525 L) Total volume (L) 517
Fridge volume - claimed (L) 400
Freezer volume - claimed (L) 117
Height (cm) Width (cm)
https://www.choice.com.au/products/home-and-living/kitchen/fridges/fisher-paykel-e521t
Apr 28, 2018 | Fisher Refrigerators
Fisher & paykel fridge e521t no power to fridge,not any power coming to fridge
Did you try an other electrical outlet? Can you test the outlet has any voltage?
does the fridge have an on / off switch? I don't think so, so if nothing works also check the cable and the plug going in the outlet.
Mar 17, 2015 | Fisher & Paykel Paykel E521TLX2 Fisher...
Fisher & Paykel E521T Fridge Ice Build up behind Freezer compartment. I have had my fridge for about 7 years and ever since I bought this fridge I have to defrost it every 6-8 months because water...
Have they cleaned the drain tube that runs down the back of the fridge? If not and the tube is clogged water will back up and give you the problem that you are having. The only other thing that I can think of, is that the defrost cycle may not be set to a minimum amount of time to where this can be increased to allow the freezer not to let the ice build up.
Apr 19, 2017 | Fisher and Paykel Active Smart E522B...
Water leaking from inside the fridge
Clear ice build up from drain plug using hot water in a syringe. Works well I just did mine. Located behind access panel inside fridge. Blue tube running down the back. Pull down and remove ice from the drain at the top.
Jun 22, 2010 | Refrigerators
Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
Jun 07, 2008 | Fisher and Paykel Active Smart® E522BR...
Refrigerators Logo
626 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
