Question about iLO 3200 32 in. LCD Television
Have sound but no picture suddenly - iLO 3200 32 in. LCD Television
  • iLO Master
  • 5,568 Answers
If it is affecting video only, the display's fluorescent back light or the power supply for it (inverter) is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself but you may be able to replace the inverter board.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a smaller separate board with some larger components on it; it will have ferrite core transformer(s) on it and some medium-size capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on either board, allow several hours to be safe since the larger capacitors in the main power supply can hold a painful voltage charge for some hours.
The section most likely to fail and cause your problem will be one that you see associated more with the display than the incoming AC line; the latter is the main power supply and its failure would result in no sound or video.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply from the manufacturer and install it yourself.
They are typically connected with non-interchangeable connectors.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since a failure of the fluorescent, while likely to be less common, is the second possibility.
Posted on Mar 24, 2011
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Viore tv sound but no picture
the sound suddenly stopped working on my Viore 42" plasma.
Aug 17, 2010 | Toymax Viore 42 in. Plasma TV
Picture is suddenly snowy - hardly visible
Try cleaning the Head with Servisol Video 40 available from Maplin or Radio Shack or other stores. They even have it on Amazon.
Oct 13, 2009 | RCA VR706HF VHS VCR
Koala babe, narrow the problem. Is there any sign of power presence in the unit. Could be just a power issue. You did not mention any lights indication on your front panel.
Good luck.
Jan 22, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Pic problem
Quasar TV SP3232. Picture disappears but comes back by striking the TV . The sound keeps coming. Perhaps something is loose
Dec 23, 2007 | Quasar SP-3235 32" TV
TV working, then suddenly no picture, no sound
could be flyback transformer cracked need replaced 48.00 for part or board replacement usually done at about $200.00 , part number is 9-2022
Nov 24, 2007 | Zenith A25B33W 25" TV
Picture and sound went out suddenly on a Sony KV-35S40
sony has problem with bad picture tubes as well as flyback transformers .if you have shorted hori output then replace it if set shorts it out again your looking at bad flyback transformer as well as maybe leaky tube.
Oct 27, 2007 | Sony KV-35S40 TV
Sound but no picture
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Nov 17, 2006 | Akai LCT2060 Television
iLO 3200 32 in. LCD Television Logo
24 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
