Question about Dremel Garden
I just bought a dremel 8000-03 and i need to know how to install the cutting attachment. i don't have the instruction manual. i need to cut down PVC pipe from our landscaping so i can install the drain covers in the planters.
  • 436 Answers
I need a manual and accessories manual for a Rotomatic dremel tool. I have a 60pcs kit but it came with no paperwork, can you help? Free if possible!
Dremel is the brand leader so your is a knock-off of it. Here is a the Dremel page with all of their manuals. The accessory kits are marketed separately and consist of cut off wheels, diamond burrs, grinding wheels, abrasive coated sponges and polishing wheels. The item does the application, the Rotary tool just provides the power.
Rotary dremel com
Yours is listed here
Rotomatic High Speed Rotary Tool With Accessories and case with manual eBay
Basic video on using attachments
Rotary Tool How to - Mandrels and Attachments - YouTube
? 4:21
https://www.youtube.com/watch?v=PyLDZcI-qxY
Jan 7, 2011 - Uploaded by Alltrade Tools
Quick video tutorial on mandrels and accessories used on an electric rotary tool. http://www.alltradetools.com.
Here is a link to dozens of videos showing how to use them.
using dremel tool Google Search
Here are videos on your specific Rotomatic
rotomatic rotary tool Google Search
Dec 11, 2017 | Dremel Tools & Hardware - Others
How to install a multipurpose cutting kit on a dremel
You will have to remove the plastic cap on the end of the tool where the tips go in. Then screw on the cutting guide.
Aug 27, 2014 | Dremel Variable - Speed Multipro Rotary...
How do i put the nail pusher spring back in the hitachi framing nail gun
Remove all bolts holding the rails to the body of the gun (make note of the position of the parts as you take then off ). Slide out the pusher assmbly. If the spring is good (wound tightly and has the bolt hole), hold the pusher assmbly in hand and attach spring to body of gun leaving bolt loose. Slide the pusher back into the rails and attach rails to body of gun up against the bolt (snug down bolt and check spring action). Re-attach rails to gun. Some after market rails do not have the slot cut into front allowing easy install of spring (cut slot with dremel). Good luck
Sep 12, 2011 | Hitachi NR83A2S Framing Nailer, Full Head,...
I borrowed my friend's Dremel to cut a few screws...originally she had the EZ Lock Cutting Wheel but it is too big so the smallest they make is not with the EZ Lock head so I was told to get Dremel 420...
I don't know what the numbers are, but the little abrasive cut-off wheels are held on with a mandrel type bit and a screw. Make sure you get the right size wheel and the right size mandrel, they make a couple different sizes, you can't fit the small wheels on the bigger screw. Anyway, I use my cut-off wheels all the time, usually to get stubborn screws out by cutting a slot in the head and turning it out with a flat blade screw driver. The wheels will cut anything, most people scoff when I say that, but it is true, they will cut anything.
Jul 15, 2011 | Dremel Garden
Which parts go on the dremel to use the cut wheel?
there is a straight shaft with a screw that threads into it that you would use for the cut wheel, don't over tighten it or you will crack it before using it.
May 17, 2011 | Dremel 100N7 Single Speed Rotary Tool Kit
How do I attach tools to my Dremel?
hello. You loosen the arbor at the base of the shaft closest to the tool. There is a tiny wrench in the kit that came with the dremel, or you can use a pair of pliers to loosen it. Joe
Apr 17, 2010 | Dremel Variable - Speed Multipro Rotary...
I have lost instructions for dremel flex shaft attachment sue
There are no manuals I have found but I have a website and phone number for them the site is Dremel.com and the toll free number is 1-800-437-3635 you can use either one to get the manual you need.
Apr 18, 2009 | Dremel 225 Multipro Flex - Shaft...
Dremel 395 rotary tool - not working
it is the coupling inside of it called a flex coupling and it seem s like it is made of wax or something. tomorrow i will go to home depot to see if they carry metal ones that won't break.
Mar 30, 2009 | Dremel Variable - Speed Multipro Rotary...
Cutting holes
My Dremel 300 came without any instructions, so I had to puzzle out how to use the circle cutter. None of the images I managed to find on the Web or elsewhere were any help. I directed my attention to the "spike" on the circle cutter, and eventually I realized that it was on the wrong (top) side of the cutter--perhaps for safety's sake. When I removed it and positioned it on the bottom side of the cutter, things became clearer. The next thing was to locate the correct cutting edge. I had never used Dremel before, so I didn't recognize the cutting "bit", since it looked like a drill bit. The final problem was how to attach the circle cutter to the Dremel tool. I couldn't see any way of fixing the cutter to the tool. I thought perhaps there was something missing--a connector, perhaps. Eventually I found a reference on the Web to "removing the cap" on the tool. I hadn't noticed a "cap", but when I gave it a turn, it began to unscrew, so I knew I was in business. Finally II tried the attachment out on a piece of scrap timber, I found that it worked. A simple instruction manual would have saved me a lot of time. Also, I now discover that the Dremel 400 would be much more useful than the 300. Dremel don't seem to be very customer friendly. I can access the US site, but the UK and Germany website won't let me in!
Sep 01, 2008 | Dremel 764 04 Pumpkin Carving Kit Includes...
Cutting wheel installation
Do not use the threaded bit. You need a mandrel that has a tiny screw on the top. Take the screw out and thread it onto the cutting wheel and then screw it back on. My book says its mandrel #401.
Jun 19, 2008 | Dremel Variable - Speed Multipro Rotary...
Garden Logo
91 people viewed this question
Top Dremel Garden Experts
ray gallant
Clyde Ottaway
Brian Krebs
Brian Krebs
Level 1 Expert
Are you a Dremel Garden Expert? Answer questions, earn points and help others
