Most lg phones will allow you to use bluetooth to send contacts. just go into contacts and there should be a settings button that has a send option in it. It should then say send via bluetooth, you choose that, and then select the contacts you want to send. From there it will ask you to turn on enable bluetooth from your phone and at that time you should also enable the bluetooth on the iphone and put it into discovery or "find me" mode. the lg will then need to search for the device. Once the iphone is found you must connect and choose a (usually) 4 digit pass code. It doesnt matter what this code is as long as you put the same one in when asked by the iphone. If this does not work or you want an easier way to do things you should just be able to go into an at & t store and they have machines that will do it for you( along with pictures and videos)
It should be the last four digits of the phone number on that phone. If it was changed, If you move the phone onto a different phone number the lock code will default to the last 4 digits of that phone number. Then move the phone back onto your phone number and it will be reset to the last 4 digits of your phone number.
