Question about Danby DWC286BLS Compact Wine Cooler
The fan on our Danby Wine Cooler (DWC1233BLSC) will not turn it just kind of clicks and there is a red and a green blinking light inside the back panel. Is this something we can fix or is it even worth it?
  • 132 Answers
You will need a new fan motor.
A technician can fix that for about $250
Posted on Mar 25, 2011
I am looking for the cooling fan for a Danby Silhouette DWC512BL-1 wine cooler. A google link took me to your site but I don't see any links to Danby parts.
As I have worked on a few ELECTROLUX wine coolers and they do not have a cooling fan for the inside of the unit are you speaking of the one under and in back of your cooler if so then it is a condenser fan motor it will be 110v and your local appliance store should be able to order one close enough to work in design and rotation of it. Hope this helps.
Apr 09, 2011 | Danby DWC513BLS Wine Cooler
My Danby has become loud and it sounds like maybe an issue with the fan. What should I do?
might be that the fan blades strike the casing. switch of your cooler. pull the plug out to prevent el-schock. turn fan blades manually and observe....
Mar 03, 2011 | Danby DWC283BLS Wine Cooler
Need to replace the fan in the upper compartment. Do I access it from inside or from the back? If from the back, do i just pry the back off? Then how is it resealed?
you must try from insyde, all my model's have acces from inside. you dont have a seal, remove carrefuly to not bent somethig and it will be ok. I presume that fan is an tangetial fan (that kind of fan have all my wine cooler's) you will need a screwdriver phillips and maybe a wrench.
Feb 21, 2010 | Danby DWC283BLS Wine Cooler
My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Nov 15, 2008 | Haier HVT12ABS Compact Wine Cooler
Magic Chef wine cooler clicking
If I was abetting man - I would suspect that the fan is polarised, and has been wired incorrectly..
Check that there is nothing obvious in the way of the fan blades..
Aug 15, 2008 | Refrigerators
Danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
May 10, 2008 | Danby DWC283BLS Wine Cooler
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Wine cooler noise
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 30, 2007 | Danby Silhouette DWC512BL Wine Cooler
Danby DWC286BLS Compact Wine Cooler Logo
192 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
