Question about Bosch SHU5316UC Dishwasher
Where can I order an upper spray arm for my bosch dishwasher
    President:
  • 1,140 Answers
Hi -
I order all Bosch parts direct from Bosch. You wont get them much cheaper anywhere else. If the model number above is correct, the part number is 359976. This is the whole upper spray arm assembly which clips onto the upper basket. The arm and retaining nut are not sold separately.
(0614 is the position number in the parts list, not the part number)
http://www.bosch-eshop.com/eshop/bosch/us/prodls.htm?Matnr=000000000000359976&ESHOPTYPE=A
$21.60 + shipping (in stock)
The link is for the Bosch USA eShop. If you are somewhere else, please let me know your location and I'll provide a different link. If you have a different from the one listed above, I can verify the part number for you, but this fits most Siemens/Bosch dishwashers, so it's likely to be the correct part..
Hope this helps.
Regards,
BElectric
Posted on Mar 24, 2011
  • 55 Answers
You can type your model number into the search box in the link below to purchase the lower spray arm assembly.
Bosch Dishwasher Repair Parts
Good luck with your repair. I know these units well and can answer any repair or review question you have.
Let me know.
Appliance & Refrigerator Repair
The upper spray arm came detached, how do I reattach it?
On my dishwasher, this arm attaches with a huge gray plastic screw. If it comes loose, you'll usually find the spray arm sitting in the bottom rack, but the screw falls down to the bottom of the tub.
The spray arm has a hole that goes all the way through its center. One of these holes is larger than the other, so the arm will only attach in one direction. Most of the spray holes on the arm face "up" when installed.
Slide out the upper rack, position the spray arm on its pivot, then insert the screw and turn clockwise to tighten it. The arm should spin freely.
If this arm isn't attached, none of the dishes will wash well (due to a loss of water pressure).
May 21, 2015 | Bosch SHU9915UC Dishwasher
How to reconnect upper spray arm bosch model 4300
Welcome to FixYa.
If you align the spray arm to the section of the upper rack which it fastens to, as shown here...
Then place it against the holder and turn, it should grab the holder, unless something else has broken...but it should be that simple.
This is the official explanation from Bosch below...
Hopefully that will help you move forward and answer you question. Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
Jan 05, 2011 | Bosch Dishwashers
The upper spray arm is not working. Any suggestions on what I might do?
THE SPRAY ARM IS CLOGGED.
YOUR FILTER IN THE BOTTOM IS CLOGGED.
THE TUBE THAT FEEDS IS HAS A BREAK GOING UP THE BACK WALL.
LACK OF WATER. ADD WATER SEE IF THAT WORKS. THEN YOU WILL NEED A VALVE.
THE SPRAY ARM TUBE IS NOT GOING INTO THE BACK OF THE FEED TUBE.
Apr 25, 2010 | Bosch SHU9915UC Dishwasher
No water pressure in dishwasher
bosch shu5312uc upper spray does not spin. pours water through the center section thus not propelling the arm. any ideas? should the upper arm have any o-rings
Dec 06, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
How do you fit the upper spray arm to the back of the dishwasher
The upper spray arm does not fit on the back of the dishwasher. There is a separate "Extra Tall Item Sprinkler" piece (about a 3-4" round gray piece that looks like a shower head) that mounts in the back of the dw.
Note that this option is only to be used with the top rack removed (i.e., for washing tall items in the lower rack). Refer to page 37 of the Use & Care Manual that came with your dishwasher.
Jun 23, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher - top row of dishes do not get clean
There is a screen that you can remove from the sump of the dishwasher to clean. Just twist it to the left and pull it out. I have some tips that you might want to check out if this does not resolve your problem.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Upper Spray Arm in the dishwasher has fallen off
If you cannot just twist it so it screws back on a part was broken.
So I suggest you contact the manufacturer about this. Im sure that will be much more helpful!
Feb 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU5316UC Dishwasher Logo
401 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
