Question about Lexar JumpDrive Classic Portable USB Data Storage Device, 128MB. (PD0128231) Media
4 GB lexar jumpstart, new on an xp which has just been reinstalled. Another computer with Windows 7 gives the same problem which is the drive only sees 1.4 megabytes. \r\n Is the flash drive fried; if not what do I do?
  • Allan Dale Dela Cruz
    Allan Dale Dela Cruz Mar 24, 2011
    have you tried reformatting the USB drive?
  • 11,800 Answers
Yes, the memory chip inside it is fried. There's nothing you can do, junk it and buy a new one.
Posted on Mar 24, 2011
Tip
How to make dual boot with window xp vista and windows 7
Dual booting Windows is the most challenging of the three options; however, making it work can be very rewarding. The process of creating a dual boot environment differs from Windows Vista to XP. Please follow the instructions according to which version of Windows you are currently using.
To run two operating systems on your computer, you will need to add a second partition. If you are not familiar with adding a partition, you can learn how in this section. Please note: each operating system will be able to see the other partition; thus, you can share files between them.
Dual Boot with window x and windows 7
You will need third party software to create a second partition for Windows 7; once you have created the partition, you can install Windows 7 on it.
Create a New Partition (Vista)
Click the Start button, right click Computer, and clickManage
In the left pane, click Disk Management
Now create a new partition by shrinking a previous volume so you can use the newly created space. Right click on the partition and clickShrink Volume.
Now right click the free space and click New Simple Volume…
Specify the volume size and click Next
Format the drive as NTFS, give it a label, and click Next
Power on your computer, insert the Windows 7 DVD, and restart your computer
Press the necessary key to initiate booting from your DVD (usually Esc or F12.)
Windows will now load the installation files.
Click Install now
Your computer will restart several times during the process as it configures itself and installs updates Be sure to leave the DVD in the drive and let Windows take care of itself.
Memory (RAM) – 1.25 GB required, 2 GB memory recommended.
Recommended 15 GB hard disk space per virtual Windows environment.
NB: Windows XP Mode is only available in Windows 7 Enterprise, Windows 7 Professional, and Windows 7 Ultimate.
on May 11, 2010 | Computers & Internet
My MacBook Pro OS X 10.9.1 won't read my Lexar Professional 800x 8 GB Compact Flash UDMA 7.
You can try using a file recovery software like Bad Copy Pro 4.10.125. It works well for me.
Jan 20, 2014 | Lexar Electronics - Others
Installed win 7 but want restore to xp
To reinstall win XP from usb flash drive you need WIndows XP cd, 1 gb flash drive and Novicorp WinToFlash. Download WinToFlash to your computer and follow instructions to transfer Windows XP from cd to flash drive, After that boot your notebook from usb device and select "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon" then install win xp normally, but format C partition. After first start of your notebook boot again from flash drive in "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon". Now windows is starting, go to start/my computer right click on it and go to properties in this windows go to advanced tab and there go to startup and recovery, click on settings, in new window go to edit tab and in new window change the line "multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP" /noexecute=optin /fastdetect" after windows XP write the type of your XP Professional, Home Edition, or Media Center. Now you can remove usb flash drive and boot normally from hdd.
Nov 12, 2012 | Advent 4211c Notebook
We are trying to work our usb
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
Aug 20, 2012 | Lexar JumpDrive S70 - USB flash drive - 8...
HOW TO INSTALL LEXAR JUMP DRIVE TWIST TURN
Windows XP, Vista , or Windows 7 should be able to automatically detect and install it.If you have an older operating system then go here for the driver:
http://www.lexar.com/downloads
May 15, 2012 | Electronics - Others
Have windows xp I need a driver for a lexar 2.0 4GB
No driver needed, when plugged in it should just appear in My Computer. If it doesn't that means the memory stick is dead, junk it.
Jul 11, 2010 | Lexar JumpDrive Classic Portable USB Data...
Dynex Easy Transfer XP to Windows 7 not working
Remove old drive from computer and install in new computer using ide ribbon. It will connect as a secondary unit and you can then using windows explorer transfer any data on old drive to new one.
Jun 19, 2017 | Dynex Computers & Internet
WDDM service not running. It's only happening to my new computer, my old one opens the 1 Tb hard drive just fine. What gives?
Im guessing since you didnt clarify that your NEW computer is running Windows 7 and the old one is running XP or an early version of Vista. The WDDM service software is picky with windows 7. You should download DirectX 11 and update the wddm drivers to 1.1 from the microsoft website.
Jun 15, 2010 | Western Digital My Book Essential Edition...
Lexar 4 GB Jump Drive
check for the USB drivers Of the Laptop.
Could be problem with the Laptop USB Controller Driver.
Jan 07, 2008 | Lexar MEDIA - DIGITAL CAM - 64MB JUMPDRIVE...
Lexar JumpDrive Classic Portable USB Data Storage Device, 128MB. (PD0128231) Media Logo
Top Lexar Electronics - Others Experts
Lawrence Oravetz
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
