Question about Sony XMGTX1852 Car Amp
Everytime I cut it on. It cuts back off like there is something wrong with it
  • Sony Master
  • 3,018 Answers
If you turn it on and it clicks right back off you may have a short. Make sure the wire panel does not have any straggler wires going from one connector to another. Also you may have a very weak fuse. Check the fuses in your amp and at the battery terminal. Make sure the power, ground and remote wires are solidly connected. Make sure that ground is tight. Is the deck shutting off at the same time your amplifier does? The remote wire off the deck powers that amp so if the deck is also cutting out the problem may be the deck and not the amp. If this is the case then run through the steps I listed above but with the deck as well.
Regards, Tony
Posted on Mar 24, 2011
2 Suggested Answers
jose_v17
  • 229 Answers
SOURCE: My amp is working but everytime it cuts off and i ...
Check your ground wire and make sure it is bolted down into a solid ground. Do not use a factory ground make your own. Every system that has subwoofers has a little blue wire called a remote wire. The deck sends a signal to the amp thru this wire letting it know it has been powered on. It could be that there is a short in this wire, either from the deck side (where the wires are connected) or it could be also be detiorated insulation on the wire. pretty inexpensive to replace. In my opinion it sounds like you have a shotty ground wire. If you don't have this grab yourself a nice foot of 4 guage wire at your local HI-Fi shop. This should fix your issue if not let me know and we will keep troubleshooting
Posted on May 22, 2010
Car cuts off
This Car is known for Cooling fan Control Modules To Go Bad! I the fan by the rad coming on when A/C is working? If it does not then that is your problem.
Apr 08, 2014 | 1993 Ford Taurus
I am driving a toyota runx 2004 model it shows P/S sign on dashboard what does it mean?
It is telling you there is something wrong with the power steering system. It cuts the stereo to draw your attention to the warning light.
Check the level of the power steering fluid is correct.
Dec 20, 2013 | 2007 Toyota Sienna
I had a transponder key cut for my 02 galant but it wont stay started. Is there any onboard programming options?
if you had this key cut at the local hardware store, all it is good for is unlocking the doors. you need a key cut at the dealer to work with your security system interlock, otherwise this is the problem you will have.
if this key was cut at the dealer and doesnt work, go back, because something went wrong with the programming.
good luck!
Aug 11, 2010 | 2002 Mitsubishi Galant
My amp is working but everytime it cuts off and i got to cut off my car and cut it back on. Also when i have the car off and i have my radio on it stays on. But when i am driving like 1 or 2 mins it cuts...
May 20, 2010 | Lanzar MXA232 Car Audio Amplifier
Amp gain problems
amp gain controll need to be changed
Jan 18, 2009 | Car Audio & Video
Amp gain problems!!!
is more than likely a loose connection
Jan 18, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
Hello, I have a vivitek 6x power zoom 5.0 mega pixels that was purchase a while back. I took a couple of pics yesterday, then cut/paste these pics onto my desktop. When I turned the camera back on after I...
It is normal merely to copy the files to your computer, not to cut and paste. By doing so, you may have corrupted the card - try formatting it in the camera, see whether that helps
Jul 27, 2017 | Cameras
Zone 2 cut off on onkyo
Your program source may not support a 7.1 format. Try switching to 5.1
May 06, 2008 | Onkyo TX-SR605 Receiver
Sony XMGTX1852 Car Amp Logo
50 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
