Question about NetGear DG834G Router
Can connect to internet via cable but not wirelessly with netgear router
  • 1,272 Answers
I understand that you are not able to connect wirelessly through the router DG834G. Please perform the below task to configure the required settings:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router's GUI by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
3. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'. Set the 'Authentication Type' as automatic. Set the 'Encryption Strength' as 64-bit.
6. In Key 1 type a 10 digit number. Apply the settings.
Please scan for the wireless network on your wireless enabled computer and connect to the network of the router using the security key as mentioned above. If the issue persists, then please let me know about the operating system installed on the wireless computers.
I hope this information allows you to resolve this issue. Please revert back for any more assistance on the same.
Regards
Anand
Posted on Mar 24, 2011
The CD is not available for installation is it necessary? I have all of the cable if the Yellow cable connects to the cable router what does the white cable on the wireless router connect to. Thank...
If the cables supplied have RJ45 connectors then they are used for connecting and configuring the wireless settings in Netgear router and to connect the Netgear to the DSL modem foe Internet access.
Most likely the color of the cables is not important.
To configure the wireless settings, connect a cable from one of the LAN ports (not the WAN/Internet port) to the LAN port on your computer. You may remove this cable after configuring the wireless settings if you want to connect to the Netgear by wireless only. You need to connect other computers to the Netgear's LAN port with a cable if they do not have wireless cards installed in these computers.
The other LAN cable is used to connect the Netgear WAN/Internet port to the DSL modem so you computers can connect to the Internet via the Netgear router.
Follow these instructions to configure the Netgear router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 23, 2011 | NetGear WGT624 Wireless Router
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
CHANGE FROM WIRELESS TO WIRED INTERNET CONNECTION
It is possible .. just get youself an ethernet cable .. connect one end to your router and the other end to the back of the pc ( ethernet port ) .. and u will be connected via the wire.. You can disable the wireless connection from the router for that you can either call your Internet service provider or the netgear support team.
All The Best!!!
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Zooless
May 24, 2010 | Computers & Internet
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
Cannot connect to internet via wireless router
You better reset it to the factory settings and reconfigure
Nov 08, 2009 | NetGear WGR614 Wireless Router
Same old question, but I cannot get a connection between my Netgear wireless router WGR614 to my cable modem.I follow the set up via the router's wizard. But no luck. Even unplugged the modem for 15 mins...
Can you pls confirm if you have cable or PPPoE connection. Also, please connect the modem directly to the computer and let me know the results:
A. Click on Start—Programs—Accessories—Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and hit 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here.
Once I have this information, it will be quite easy to configure the router.
Oct 09, 2009 | NetGear WGR614 Router
My netgear will not let me connect to the internet via my wireless connection my main computer has internet as it is connecter via the yellow cable to the netgear my other computers have a netgear adapter...
Open Zonealarm, choose Firewall, Zones.
Add >> IP Range set your IP range eg 192.168.0.1 to 192.168.0.254
This should allow connection between Router and Wireless Laptop/Desktop.
If your wireless PC cannot see the router, check your router setting to see if you are transmitting a SSID
May 18, 2009 | NetGear DG834G Router
Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Jan 19, 2009 | NetGear WGR614 Wireless Router
Netgear wireless router DG834PN wireless access local only I can get internet on my desktop which is connected to the router via ethernet but I can connect to the router wirelessly on my laptop but only...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To start with plug the LAN cable, type 192.168.0.1
into your browser, a netgear window should come
up name is (admin) PW is (password) default.
goto to wireless settings.
Tick Enable Wireless Access Point
Tick Allow Broadcast of Name (SSID, give it a name
Under security options, Tick none
Hit apply and exit
Setup your laptop up with no security to start with, the laptop
Should now see the Netgear SSID name you made.
After this find out your laptops MAC address, log back onto the
Netgear unit, add the MAC address to the allowed list, hit apply
And exit, now only your laptop will be able to get a wireless connection.
Hope this helps
Have a nice day
Aug 14, 2008 | NetGear WGR614 Wireless Router
NetGear DG834G Router Logo
88 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
