Question about Lexmark T644dtn Printer
What does "vertical line error"
    Novelist:
  • 137 Answers
Toshiba 27af45
What do mean by the vertical going up and down. Do you mean that the picture collapses to a vertical line then is good, then back to a line? If so then you have an intermittent/cracked solder joint at the vertical output IC. If you have no experience in soldering, then please have it repaired by a service center.
Dec 26, 2013 | Televison & Video
I have a Nikon D100 with a Nikon AF Nikkor 24-85mm 1:2.8-4 D lens or a Nikon AF-S Nikkor ED 7-300mm 1:4-5.6G VR lens. I'm on vacation in Hawaii and am troubled by an error that appeared today. The...
Hi
i know what exactly the problem, but if your unit is under warranty go to Nikon service center the problem is in hardware and only Nikon can fix that..and only nikon have parts for that!
Thanks! Likha
Sep 23, 2008 | Nikon Cameras
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
Vertical laser error
If the error code means "vertical laser error" you could check for the flat connector of the vertical laser module. Here I send to you an image to explain it. 0b500ff.jpgIF all is ok. you could try with another vertical laser board and replace it
Apr 20, 2010 | Datalogic Magellan 8500 Wired Barcode...
PHP Parse error
sir :
Do you have a problem in your own web page or what?
This mistake frequently occurs when a particular quote is
present in a string delimited by the same kind of quotes,
for example:
echo 'apple API';
In such situations the PHP interpreter does not know when he
starts and ends where the chain. The solution is to "escape"
quotes problem by being preceded by a backslash
(backslash):
echo 'apple d \' api ';
In the same way for the double quotes
echo "said Jacques \" Hello! \ "";
The PHP parser generally indicates the line where
the error occurred.
This error may also be due to the oblivion
of a semi-colon (;) at the end of the investigation
into the previous line ...
please dont forget rating this comment.
if this not helping u tell me so i can help u
Aug 26, 2008 | The PHP Group PHP
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
282 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
