Question about Honda Garden
NEED SPARK PLUG GAP FOR A HONDA DELTA PRESSURE WASHER MODEL NO. DT2400CS
  • 10865 Answers
SOURCE: honda powered gx160 model pressure washer wont start
Buy a new plug, drain out all of the old gas and put in new gas, and take a look at the air cleaner. If the air cleaner is dirty replace it. There you now have a good spark, good fuel and good air. The engine should start. If it doesn't get some carberator cleaner spray and some starting fluid spray.
Posted on Apr 12, 2009
comax
  • 154 Answers
SOURCE: Does anyone know what the spark plug gap setting
Most gas engines will work fine at .030 to .035 sparkplug gap
Posted on Apr 16, 2009
  • 174 Answers
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Posted on Jul 19, 2009
  • 68 Answers
SOURCE: NO PRessure
Hi It sounds to me like your unloader valve is stuck, this is the thing that is meant to move up and down when pressing the trigger.Please remove the unloader valve assembly and check for damage. If no damage is found then grease and lubricate this part and replace and this should work ok again.
Posted on Jun 16, 2010
  • 13 Answers
SOURCE: I have Craftsman 6.75 horsepower pressure washer
Replace the gas, check the air filter is not clean.
Posted on Sep 06, 2010
What is spark plug gap on unidentified pressure washer?
Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonLearn how & where to find the right spark plug and a gap chart to guide you through ...are commonly used for walk behind lawn mowers and pressure washers.
Spark Plug Gap - Troy-Bilt
Nov 24, 2015 | Garden
No power to the spark plug
Take the spark plug and connect the plug wire to top like it is supposed to be. With plug out of machine rest base of plug against metal of head (anywhere on motor near plug hole) and try pulling fast and look at gap in plug for spark. You have to make sure base is getting good ground to motor but if system working you should see a spark. If not you need to first check for small black wires that come from coil and go to throttle linkage point, or other "kill" switch to make sure the wire did not come off and is touching something. Some machines have a few ways to kill motor with the small wires (like a dead man switch on mower) that need to be checked for possible issue. If the kill systems seem to be working then coil is probably gone. To change coil you have to take engine covers off and pull flywheel to get at coil. You need a wheel puller to take flywheel off. If you have the tools it is not hard but if no tools it is tough.
Jan 17, 2015 | Briggs Pressure Washer Pump Delta Vr2522...
Want is the spark plug gap on a Honda GC160 - 5.0 model # wp2003omhb
usually honda uses 0.024in spark plug gap, if you are using new plugs they specifically say that they do not require being gaped, if you are maintaining old plugs use 0.024in as the Honda standard.
Apr 30, 2014 | Honda Garden
Pump will not unload.
Hi if it stop when the trigger is pulled the issue is with the motor.
stopping is caused by , low revs on motor or low compression or poor spark, sometimes faulty carby.
change spark plug , adjust valve ( when valve has some slight side movment it is ok if up and down , it should be tighter (valves usually under side cover near top ) increase revs a little ( make sure revs dont get rough when running high) set max revs to when the engine still runs smoothly at max.
Mar 30, 2014 | Delta Model DT2400CS Pressure Washer 5.5HP
Only runs on choke
clean carburetor jet and fuel tube you have to remove the carb bowl and unscrew the jet and pull the tube down.
Aug 15, 2013 | Delta Model DT2400CS Pressure Washer 5.5HP
What is the Spark Plug Gap for a WorkForce WF80911 Pressure Washer?
For spark plug gap understanding,click the help link below:---
How to gap spark plug? http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Thanks.
Nov 16, 2012 | Cars & Trucks
What is the spark plug gap?
Hi Mike,
If you can identify the model of Honda engine on the washer, you can download the service manual from this webpage:
http://engines.honda.com/models/application/pressure-washer
Hope this helps!
Apr 06, 2011 | Porter Cable PCH3200 Commercial Pressure...
NO PRessure
Jun 15, 2010 | Honda Pressure Washer PSI 3000
Garden Logo
292 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
