Recently my benq mp620p projector stop working. When I connect the power cord the power button lights up green and the power led orange as usually. When I push the power button, it starts to blink in green, the filter wheel starts to spin and the lamp starts to warm up with some light comming out. Few seconds after, the fans start, the power led becomes solid green and the lamps goes of. I can't do anything else since that other than unplug the power cord. No response to any button. Any help?
  • 11,800 Answers
I'm assuming that you have checked the bulb and it appears ok. Either the inverter/ ballast board has a fault or , much more likely, the control board is no longer capable of finishing the loading of the firmware. This is usually caused by the failure of the microprocessor, which means that the entire mainboard would have to be replaced.
This is doable but not cost-effective: it will be cheaper just to buy a new projector. To identify the problem the voltages on the power and ballast board will have to be measured - beware, they are extremely high, a special multimetre will be necessary.
Posted on Mar 24, 2011
My Projector Benq Mp620p Green Light is Blinking
Hi Ahmed, if only the green light is flashing, it means that it is powering up.
Mar 25, 2015 | BenQ Office Equipment & Supplies
How connect to BenQ mp620p- xBox360 ? Thanks good luck
If you've got the version with a DVI input, use a HDMI to DVI cable. That'll take care of picture but not sound. You need to hook up an audio cable that finishes in a 3.5mm stereo jack if you want to use the Benq's speaker.
If you have the older version with just a VGA input then buy an Xbox 360 VGA cable. You'll also need an audio adapter; 2x phono/RCA sockets going to 3.5mm stereo jack.
Sep 09, 2014 | BenQ MP620p DLP Projector
I have an orange light blinking on the power and a red (steady) on the lamp? What is the problem?!
The projector bulb has failed to light.
This could be due to a bad connection on bulb (remove and reinsert ) or that the bulb has failed.
Unfortunately they are not cheap.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | BenQ MP620p DLP Projector
How can i reset a password for benq mp620p projector
Hi,I have a Benq mp610 projector that I have forgotten the password for so need the code to unlock it. The recovery code for it is 21182 13770 6789 8385
Jan 14, 2011 | BenQ MP620p DLP Projector
How do I get the laptop screen to project when I
You can download the manual from the manufacturer's web site at
ftp://downloads.benq.net/projector/manuals/mp620-mp720/mp720-en.pdf
Mar 31, 2010 | BenQ MP620p DLP Projector
Ink absorber full Canon MP210
(11/24)
<Service mode operation procedures>
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
(11/24)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print See APPENDIX 1:
SHIPMENT INSPECTION
PATTERN 1: PRINT
SAMPLE
2 times Green EEPROM print See APPENDIX 2:
EEPROM INFORMATION
PRINT
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
(12/24)
<Destination setting procedures>
At Logic board replacement, make settings for each destination.
button pressing
LED Destination Paper for defaulte setting
0 time Green No change
1 time Orange Japan A4
2 times Green Korea A4
3 times Orange US/Canada Letter
4 times Green Europe A4
5 times Orange Australia A4
6 or more times Returns to a menu selection A4
<Waste ink counter reset procedures>
At the waste ink absorber replacement, reset the waste ink counter for the replaced waste ink absorber.
Setting operation for the waste ink counter (The counter setting value is selected by pressing the Reset button.)
The number of the Reset button
pressing
LED
0 time Green Reset the main waste ink counter to 0%.
1 time Orange Reset the platen waste ink counter to 0%.
2 times Green Reset the Main & platen waste ink counter to 0%. (Reset
collectively.)
<Button / LCD checking operation procedures>
At Operation panel unit replacement, check the button / LCD.
1. When pressing the Stop button two times, the machine will be moved into an LED confirmation mode.
2. As often as the Color button is pressed one time, each LED is lit one by one, and the machine get in the mode in which each
button is acceptable.
3. As often as each buttons on the panel is pressed from the left to the right, the displayed number is counted up.
Pressed button Display
Maintenance 1
Fit to Page 2
SCAN 3
Paper size 4
+ 5
Black 6
Color 7
Stop / Reset 8
On / Off 9
4. When all buttons are pressed, [1] will be displayed. Then, LED[8.5 x 11 Plain Paper] and LED[8.5 x 11 Photo Paper] will be lit on
the panel, and the machine will be in a service mode menu selection mode.
May 20, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
