Question about HP Photosmart C5180 InkJet Printer
How do I enlarge a copy on my hp photosmart d110 printer
  • 38 Answers
SOURCE: how to set wireless conection in VIsta of HP Photosmart C4580
Download what you need from hp.com
Posted on May 27, 2009
rh10
  • 122 Answers
SOURCE: Setting up wirless connection for D110 Photosmart
WEP or web encyption protocol is the encryption code used to protect wireless systems to stop others "borrowing" your broadband. If you haven't got one set up I suggest you do so. Use letters (upper and lower case mixed) and numbers. This is the code then that you give your printer. Make a not once you add it into your router and keep it safe.
An example of a WEP could be
a67DD1iPp84wSq
Posted on Jul 16, 2010
SOURCE: my hp photosmart C4780 printer
While the print function will still work, the copy function won't work if ink is low.
Posted on Oct 04, 2010
Testimonial: "OK Tks for the hint..it was one of the alternatives"
upvansh
  • 119 Answers
SOURCE: Is there an opperators manual for the Hp
Hi
Please click on the link below and you would see 2 options
1. Reference guide
2. User Guide
Please click on user guide
It would open the PDF or adobe document
Click on 'File' on the top left hand corner of the page and click on 'Save as' and save it on your computer
You need not to print this user guide because it contains 52 pages, so it would be a waste of ink
So you can keep it on the computer and when required you can open it up
Posted on Oct 27, 2010
mediastormer
  • 135 Answers
SOURCE: I am setting up a
Step one: Load the correct type of paper Remove all the paper from the tray. NOTE: Colored, photo, or used paper can cause the alignment to fail. Load unused, plain white, letter, or A4-sized paper with a brightness level of at least 85 into the tray. NOTE: Look for the brightness level on the paper packaging. Step two: Align the All-in-One Press Setup . Press 5 . The product opens the Tools menu on the control panel display. Press 3 to select Align Printer . The product calibrates, aligns the printhead, and then prints an alignment page. Recycle or discard the alignment page. Video of aligning the All-in-One The following video demonstrates the steps for fixing a carriage or paper jam. The product shown in the video is the HP Photosmart C7280. The outside of the product might look different, but the steps are similar for the same for the HP Photosmart 3100, 3200, and 3300 All-in-One series products. If you have trouble viewing the video or to view the video in a different size, click here to play the video (in English) on YouTube. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step three: Clean and reinstall the cartridges If the contacts on a cartridge are dirty or do not seat correctly, the alignment might fail. Follow these steps in the order presented to clean and reinstall the cartridges. Gather the following materials: Soft, lint-free materials, such as foam-tipped swabs, that do not stick to the electrical contacts Clean, lint-free paper to rest the cartridges on (coffee filters work well) Distilled water Press the Power button to turn on the product. Open the cartridge door. Squeeze the tab below the black cartridge on the far left side of the carriage, and then lift the cartridge latch. 1 - Cartridge latch for the black cartridge 2 - Cartridge latches for the color cartridges Remove the cartridge by pulling it toward you and out of its slot. CAUTION: Do not remove multiple cartridges at the same time. Remove, clean, and then reinstall each cartridge one at a time. Do not leave a cartridge outside the HP All-in-One for more than 30 minutes. Inspect the cartridge contacts for ink and debris buildup. Dip a clean foam rubber swab or lint-free cloth into distilled water, and then squeeze any excess water from it. NOTE: Hold the cartridge by its handle. Do not touch the copper-colored contacts with your hands or anything other than a foam rubber swab or lint-free cloth. Clean only the copper-colored contacts. 1 - Copper-colored contacts Slide the cartridge back into the empty slot. Secure the cartridge in the slot by pressing down on the latch until it clicks into place. Repeat steps 2 through 5 for each of the cartridges. Close the cartridge door, and then try to align the product again. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step four: Check the ink levels Empty or nearly empty cartridges can result in alignment failures. Follow these steps in the order presented to check the ink levels in the cartridges. Press Setup Press 5 , and then press 1 . The Tools menu displays. Click Display Ink Gauge . The gauges for the six cartridges display. Check the gauge for empty or almost empty cartridges, and then replace any you find. The product automatically performs an alignment and prints an alignment page. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step five: Replace the cartridges Follow these steps to replace any cartridges that are empty or low on ink. Open the cartridge door. Squeeze the tab below the black cartridge on the far left side of the carriage, and then lift the cartridge latch.
1 - Cartridge latch for the black cartridge 2 - Cartridge latches for the color cartridges Remove the cartridge by pulling it toward you and out of its slot. CAUTION: Do not replace multiple cartridges at the same time. Replace each cartridge one at a time. Do not leave a cartridge outside the HP All-in-One for more than 30 minutes. Remove the new cartridge from its packaging, and then, holding it by the handle, slide the ink cartridge into the empty slot. Slide the new cartridge forward into the empty slot. Repeat 2 through 5 for each of the cartridges. Close the cartridge door, and then try to align the product again. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step six: Reset and relocate the product A power reset drains power from the product and returns the product to the same settings after restarting. Moving the product to another location and plugging it directly into a wall outlet can eliminate any potential power deficiencies that might prevent a successful alignment. Make sure that you have the product turned on. If necessary, press the Power button to turn on the product. With the product turned on, disconnect the power cord from the back of the product. Relocate the All-in-One to a different power outlet, preferably in a separate room Plug the power cord directly into the wall outlet. Do not use a power strip. Reconnect the power cord to the back of the product. Press the Power button to turn on the product. Load plain white paper into the tray. Try the alignment again.
Posted on Oct 30, 2010
My i phone 4 does not recognize my wireless hp printer 4500
Currently to use iPhone to use printing you need a airprint enabled printers! below is a list of them!
HP Deskjet 3050A e-AiO HP Envy e-AiO (D410) HP Photosmart Plus e-AiO (B210) HP Photosmart Premium e-AiO (C310) HP Photosmart Premium Fax e-AiO (C410) HP Photosmart e-AiO (D110) HP Photosmart Wireless e-AiO (B110)-Europe and Asia-Pacific HP Photosmart eStation (C510) HP LaserJet P1102w HP LaserJet P1606dn
there are more to this list and for information check http://support.apple.com/kb/HT4356
Sep 08, 2011 | Computers & Internet
I have lost my startup disc for my wireless hp photosmart printer D110 series. how can i hook it up to my computer without it
You need to download the drivers for your hp photosmart printer D110 Go to this link: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=4023246
When you get there, select where you see "Operating System", select your operating system (ex: XP, Vista, or Windows 7). It will then show all the drivers.scroll down and then download and reinstall it. Hopefully this will help...good luck.
Aug 29, 2011 | HP Office Equipment & Supplies
How do I enlarge copies on my photosmart C6180 printer
To Enlarge or Reduce.
1. Press Copy Menu
2. Select Size
3. Select Custom 100%- Hit O.K.
4. Custom percentage shows up
5. Use the Up Down function to enlarge or reduce
6. Hit Preview Button
7. If O.K. Press Start Copy for B/W or Colour
Feb 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
I bought my daughter an HP photosmart D110 Series printer for xmas. I set it up here at home using wireless, not USB, and it worked great. Now when she gets to her apartment which also has wireless, we...
start new,
use the D110 full setup instructions from scratch.
install the software from HP.
then on some printers, like mine, the USB way works or wifi
if you set it up to wifi , usb is dead.
and the reverse.
so must be reset , per the manual to get it the way you want.
it is a very complex device, this all in one e-printer
https://support.hp.com/us-en/product/HP-Photosmart-e-All-in-One-Printer-series---D110/4023244
wifi, is complex.
first the user must know the routers settings to make it connect.
but some times you have no access to that router, due to owners
are ISP or landlord.
to use wifi , i must force my router to use a fixed IP (reserved)
or will not connect , reliably, the manual covers this too.
use the HP install package,
rule 2:
NOTE: If the printer is connected with a USB or Ethernet cable, the printer cannot connect wirelessly.
click does not maintain wireless....., seen here.
it tells you to run the hp print and scan doctor there.
Aug 21, 2017 | HP Computers & Internet
I can't figure out how to enlarge copies on my printer
From printers front panel
Press setup > copy menu >
  • Size
    • Actual Size
    • Fit to Page
    • Custom 100% (Use arrows to change percentage)
  • Jul 21, 2010 | HP Photosmart C5180 All-In-One InkJet...
    How do I set photosmart B209 to enlarge copies?
    http://h10032.www1.hp.com/ctg/Manual/c01796502.pdf
    Pg 57 Item c, where is says touch size, instead of fit to page, you should have other options to increase or decrease the size.
    Another option it to scan the item to the computer then print and enlarge during the print process
    Mar 15, 2010 | HP Photosmart C6180 All-In-One InkJet...
    HP C4580 PhotoSmart Install Crash
    Dial 1-800-436-0509 for technical support for HP Photosmart C4580 All-in-One Printer, HP Photosmart e-All-in-One Printer D110, HP Photosmart 8450 Photo Printer Series and best hp printer of 2017 HP Sprocket Photo Printer-One 1 800 436 0509 HP Printer Technical Support Phone Number
    Apr 04, 2009 | HP Photosmart C4580 All-in-One InkJet...
    HP Photosmart C5180 InkJet Printer Logo
    978 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
