Question about Zanussi 24 in. DA6153 Free-standing Dishwasher
ZANUSSI DA6141 Dishwasher Stops about 10min in, and it blows the fuse in the plug, open the door and water is hot, I change the fuse and set it on drain and it drains ok. I looked at the On/Off Switch it appeared to be discoloured so I ordered a new one changed it with no problem but the dishwasher stopped at exactly the same point (I know this as I marked the dial) Any help would be great thanks Nick
    Top Expert:
  • Zanussi Master
  • 26,697 Answers
Possibly a broken heater element.
Posted on Aug 03, 2017
  • 641 Answers
SOURCE: zanussi dishwasher DA 6141 6 years old
Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
Posted on Sep 02, 2007
maklean
  • 1665 Answers
SOURCE: zanussi da4342 dishwasher
The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues.
Another possible reason is that the timer unit is defective. If you have observed anything different post a comment.
Posted on Jan 12, 2008
Trifect7
  • 57 Answers
SOURCE: dishwasher zanussi zsf 6128
Either it's not getting enough water to flip over to the next part of it's cycle (unlikely) or the water float gauge is not working properly.
When the dishwasher is cool, look for the float inside the dishwasher --usually a small plastic dome or cylinder mounted inside at the tub's base, near the front. When you move most types of floats up and down, you can hear them click because they trip a lever (they are spring loaded). Lift out the float mechanism and clean around the float tube; many floats must be disconnected from below--to do this you'll have to remove the lower access panel. Rinse off the float, then replace it in the tube and be sure it moves up and down freely.
If you're experienced with minor repair work shut off the hot water valve to the appliance. Locate the water intake valve, behind the dishwasher's bottom front panel, disassemble the valve to reveal the screen, clean debris from the screen, and reassemble. If the screen doesn't appear to be blocked, call a repairperson (they will probably need to replace the water intake valve).
If none of this helps, call a repair person. Any of several parts, including water inlet valve, pressure switch, and the timer or selector switch, may be faulty.
Posted on Mar 02, 2008
SOURCE: zanussi ls9 dishwasher
check your boiler,maybe there is no water there
Posted on Aug 03, 2008
  • 1531 Answers
SOURCE: Dishwasher not draining water
the model number is or should be located on the right side of the.cabinet where the door opens.any how the problem could be a clog in the drain hose. you can remove the hose from the side of the garbage disposal.use a shop vac and try and drain the water that way if it does not drain then you could have a grease clog if there is grease clogging it use a blow dryer to heat the hose up and this should remove
the clog.if the water does come aut the you may have a bad drain pump and or a control board.
Posted on Jan 24, 2010
Water does not drain after cycle and dishes are not cleaning
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Mar 14, 2011 | Zanussi 24 in. DA6141 Built-in Dishwasher
DA6141....DOES IT HEAT THE WATER? CAN ONLY SEE A HOT WATER INLET PIPE TO THE REAR....
Your dishwasher uses your hot water to wash the dishes.
Attach your hot water to both the sink and dishwasher at that (hot water) inlet.
Run the hot water in your sink until it is very hot, then turn on your dishwasher.
Jan 09, 2011 | Zanussi Dishwashers
Will not drain
I hope this helps.
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
Let us know if you want something more else please accept the solution.
Thank You for contacting Fixya.com
May 29, 2010 | Zanussi 24 in. DA6141 Built-in Dishwasher
Water not going into dishwasher
make sure the water supply line is turned on and that it isn't kinked.
Sep 17, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
Buit in dishwasher
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
iio
Jul 08, 2008 | Zanussi 24 in. DA6141 Built-in Dishwasher
Smell of burning
The Element is shorting out, tripping the rcd. replace the element, thermostat,and any cut outs that are in the element cricuit. The element should not be glowing which means the stat is shot and the safety cutout for the element is shot also, while you`re at it check out the circuit board for dry joints, discoloured resisters, bulging capacitors etc.
This is VERY dangerous situation, as the machine has the potential to set your house alight and burn it down!. If you continue to use it in it`s current condition you may well damage other componants - rendering the machine B.E.R - Beyond Economical Repair. I will will advise You to never to leave this machine unattended, do not go out after turning it on and have a nice afternoon in the park etc, you may well come home to a pile of ashes!
Feb 18, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi FLE1416W Front Loader
Most possible reasons that the door switch or timer unit is defective. The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. if you think that a user manual may help you more, it can be downloaded ($8.95) at url: http://www.download-manual.com/shop/Zanussi-FLE1416W-User-Manual-pr-8261.html
Jan 22, 2008 | Zanussi FLE1416W Front Load Washer
Zanussi aquasave dw24
hi there sounds like your door latch switch could be at fault.
hope this helps
Nov 08, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Power tripping
First off, lets make sure its not the wiring in your house. disconnect the dishwasher and plug in something else and see if it trips the fuse. also what amps is the breaker rated at?
Nov 02, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Zanussi dishwasher DA 6141 6 years old
Sep 02, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Zanussi 24 in. DA6153 Free-standing Dishwasher Logo
73 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
