Hi experts! I've moved into a new Flat but there wasn't a manual left for the immersion heater timer. At the moment I'm leaving it on all the time which no doubt will start to cost more money than necessary. If possible I'd like to set timer to heat the water at cheap times. But I want hot water for definite at 8:00am and 8:00pm each day. If anyone knows how to set it that'd be great. If not, a link to a manual, or place to purchase one would also be a great help. I can't find the model number so 2 images are linked: http://imgur.com/a/Ta66m Cheers!
    Brigadier General:
  • 4,736 Answers
Mikey Mike, I think I may have found a link that you can find the Owners Manual you're looking for. You'll need to pick one that looks like yours (since you don't have a model #), click on it and after it takes you to another page, browser back and look at the top right corner and you'll see a highlighted technical link. Click on it and it will take you to the Owners Manual for that particular model.
By the way, your timer is manufactured under the name TRAC Immersion timer.
I hope this helps, because finding things in the UK ain't easy, for this good ol' boy from the US. If does, please leave me a good rating. Thanks!
http://www.tlc-direct.co.uk/Manufacturers/Trac/Timers_Wired/index.html
Posted on Mar 25, 2011
Need instructions for grasslin 16 amp immersion heater timer
https://fauroanofi.files.wordpress.com/2015/03/grasslin-immersion-heater-timer-manual.pdf
Apr 21, 2015 | Hardware & Accessories
My EJ35IC timer seems to be preprogrammed, and i cannot erase it. can you help? thank you
There is no repair for defective timer.
Unknown if this is new timer, or timer that worked before and stopped working.
Add a comment any time.
Try resetting timer using instructions from manual: Move control lever to OFF-CLEAR position for about 20 seconds. Red indicator light will go off, and all previous programming will be cleared.
Then move control lever to ON position and red indicator will start flashing. Reprogram timer.
If functionality is not restored, then timer might be defective.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
Timer has 1 year limited warranty fro Intermatic:
http://www.intermatic.com/customer%20service.aspx
Resources:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 18, 2011 | Intermatic Programmable 24 Wall Switch...
I have a Utilitech In Wall Digital Timer Lowes Item #: 141224 | Model #: LW60418, purchased from Lowes. I've lost the instructions and can't figure out how to set the timer after a power...
Open following link for Utilitec timer manual:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer should have a back-up capacitor so that programming is kept in memory during power outage.
Power outage is known cause of timer failure. When power turns on, the surge knocks out electronics.
People writing to fixya report electronic timers and electronic water heater controls stop working after power outage. Probably many other electronic devices are affected too, but that would be out of my specialty.
Troubleshoot says 'in case of operational failure, press reset button to clear all settings and restart.'
If timer has failed, buy another from Lowes and return defect in new package.
Take a moment and rate answer:
Sep 11, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Just replaced my electric water heater this morning. When power was restored, my intermatic timer begain making a high-pitched squeal. What is this?
Probably some dirt fell on the gears inside timer.
Turn off power and spray WD40 on gears.
Or blow out timer with air.
Open following link for photos, illustrations and resources.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html#clock
Sep 06, 2011 | Intermatic WH40 - Water Heater Time Switch...
I have a Utilitech one outlet light timer and I can't get it to work! I've never had a problem with a light timer; they're pretty straightforward in how to use them. I set the current time,...
Thank you for including model number.
TM01DHBL is typical analog timer with 1/2 hour segments located around edge of dial.
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#59366
There are no repairs for defective timer: Here are suggestions.
1) Locally purchased timer has longer warranty period since you can buy same timer later and return defect in new package.
2) Top of timer has slide switch. Most analog timers have 2-or-3 position switch that offers override capability. Set some segments, move slide switch each direction, and then manually rotate timer dial clockwise two full revolutions to watch how lamp turns on-off.
If lamp does not turn on-off with switch in at least one of the slide-switch positions, then timer is suspect.
3) Always a good policy to test outlets with cheap circuit analyzer to check for electrical abnormalities that can affect timer electronics.
Since this is mechanical timer with simple electric clock motor, chances are that reversed polarity will not immediately affect timer.
4) Put timer on a different outlet, controlling a different load, and see if problem is the same.
5) Make sure segments are pulled all the way up.
Aug 30, 2011 | Hardware & Accessories
Can I move the stationary pointer clockwise and counterclockwise or will it break the devise
It is not necessary to move stationary pointer:
The stationary pointer points straight down at 6:00, and is used as a mark for setting current time.
Lift and rotate yellow dial until current time lines up with the pointer.
It will not break anything by moving the pointer, but you might forget the current time location.
Open following links to explain how timer works:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#pool
Take a moment and vote on answer:
Aug 27, 2011 | RTO Intermatic T104R3 Timer Switch 220V -...
I've had my Grundfos Up1510SU7P for about 5 yrs. Recently, it started sending scalding hot water to the faucets. Could it need a new value? I've tried to find a manual for this for any...
It sounds like thermostatic operation is not working.
I cannot offer specific repair, but can offer resources
1) Grundfos service options and warranty information + local distributor of parts and service center finder:
http://www.grundfos.us/web/homeus.nsf/Webopslag/OMAT-5S7J7X
2) Terminal strip and capacitor replacement does not show UP1510SU
http://www.us.grundfos.com/Web/Download.nsf/Pages/F3A9576228BA79AF0825691A006D2D0F/$File/Luptl028.pdf
3) Open following link for recirculation system resources including some manuals, but I don't have your exact manual.
http://waterheatertimer.org/Water-heater-recirculation-system.html
I can see your product on following link
http://www.houseneeds.com/shop/plumbing/recirculators/waterrecirculatorindex.asp
4) Recirculation systems operate 2 ways: with thermostat or timer.
Thermostat is supposed to turn off circulation when water reaches 100 degrees approx.
Until thermostat is repaired, you can work around problem by moving slide switch to TIMER and set timer to run intermittently so temperature at faucet is moderated.
5) Adjust temperature at water heater
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Upvote the help.
Jun 01, 2011 | Grundfos UP15-10B5/ATLC 1/25 HP ...
I just moved in to a new house and the water heater is hooked to an intermatic T 171 timer. I have set the trippers in different positions and the time of day is correct, but I still cant get hot water...
Open following link for Intermatic troubleshoot checklist.
Once timer checks out, you need to check circuit going to water heater.
Water heater might be the problem.
Remove trippers from timer dial and set override lever to ON.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Add a comment for more free help
Also take advantage of fixya expert assistance live.
May 01, 2011 | Intermatic T171 - 24 Hr. Dial Time Switch...
I have the imm24 timer and would like a better quality timer which one will work
Imm24 timer is 230V 3500amp flush-mount hard-wire 24-hour mechanical-dial immersion heater timer
Following page shows imm24 timer and other brands of immersion timers
http://cpc.farnell.com/1/1/51662-immersion-heater-controller-box-imm24-apt.html
Prices are in Euros and Pounds, so I don't know distribution range of product.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 03, 2011 | Hardware & Accessories
I have just moved into my new apartment it as a newlec nle7 water heater with a timer, i can't get it to work, i need a user guide manual lisa
I think it is the same as the Horstmann Electronic 7 immersion heater timer. You can download it free from the Horstmann web site.
Dec 24, 2010 | Heating & Cooling
Heating & Cooling Logo
243 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
