Question about Hotpoint Washing Machines
Need to replace the drum bearings in my hotpoint bwm129. What is the procedure for this?
vest6
  • 196 Answers
SOURCE: hotpoint bwm129 lights flashing
What mode are you starting this machine in ? I know this may sound silly and I'm trying to determe if this is a machine fault code or something else.
Posted on Jan 02, 2008
  • 82 Answers
SOURCE: hi my washing machine model bwm129 bearing has
Hi, most engineers would charge £90 just for the bearings. It's quite a big job.
Hope this gives ou some idea.
Posted on Sep 29, 2009
  • 153 Answers
SOURCE: Replace drum bearings on hotpoint aquarius wf000g
You really don't want to know how but here it is. The bearing is located in the rear shell and is not removable the rear shell has to be replaced which means removing the tub assembly from the machine and completely disassembling. With 30 years of appliance repair the last one I did took about 3 hours.
Posted on Feb 26, 2010
apart4u
  • 213 Answers
SOURCE: Hotpoint WMA66 Drum Bearings gone. Drum will not ...
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Posted on May 27, 2010
  • 662 Answers
SOURCE: Need to replace the door seal on a Hotpoint BWM129
For some front-loaders:
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
I have a Hotpoint BWM129 washing machine and the Delay start and Superwash lights are flashing. Can anyone explain what fault code this is? The door locked light is also on.
Manual says to unplug maching from wall for at least 40 seconds to a minute. This will reset the unit. If that does not work you will need to call a service tech.
Jan 30, 2015 | Hotpoint Bwd12, Bwd129, Bwm129 Washing...
Change hotpoint wmd 962 g uk drum bearing
Hotpoint dont sell the bearing for WMD962 seperately. You have to replace the whole drum unit.
Dec 01, 2012 | Washing Machines
Noise in drum sound like its gonna blow up
hello, unfortunately the wf321 drum does not split the bearings and drum come as one complete unit and so you need to order a drum unit complete with new bearings and replace the lot
Jun 02, 2010 | Hotpoint Washing Machines
Tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Jan 31, 2010 | Hotpoint Dryers
Hi my washing machine model bwm129 bearing has
Sep 28, 2009 | Washing Machines
Loud noise as drum turns,gets louder as speed increases.
There is no doubt that the drum bearings have failed from your description.
The normal procedure is to replace the whole drum and tub assy as a complete unit, this makes it a fairly straight forward repair, though relatively expensive.
To strip it down and replace worn bearings, is a very involved repair, and not one I would recommenend.
If the washer is less than 5 years old, then you can get it done under the Hotpoint 5 year part guarantee, but you would have to contact Hotpoint about this.
Plz rate my solution.
Thankyou.
Jan 25, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Suspect bearings gone
I do not advse you to attempt to change the bearing, it is a very involved repair, and you need to know what you are doing. the normal procedure is to change the whole drum assy.
Check with Hotpoint
Aug 10, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint bwm129 making huming noise
Sounds like the rinse water can't come. Maybe the solenoid for cold water got stuck or a water filter needs cleaning? If the humming is louder, perhaps the drum motor (or drum) needs a little care or cleaning.
If all else fails, download the user manual and check the trouble checklist index. (Or; try learning your kenpo succession move sparring against laundry to clean it.)
Apr 14, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint bwm129 lights flashing
Dec 30, 2007 | Hotpoint BWM12 Front Load Washer
Washing Machines Logo
106 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
