Question about Toshiba COPIERS E-STUDIO 520 Copier
Toshiba e studio 520 copy machine feeds paper extremely slow...takes forever for scanned documents to be emailed...some type of network problem?????
  • Toshiba Master
  • 653 Answers
Did u try scan to E-Filing only? See whether got faster or not.
Posted on Mar 30, 2011
  • didi2005 Apr 02, 2011
    Try also reformat the Hard drive.
    Method:
    Enter 08 mode by holding 0+8 keys and ON the MFP
    Enter "690"
    A value of "2" will be shown on the panel
    Press "START" to reformat the HDD
    Then reboot machine.
    PS: All storage on E-filing will be missing after reformat the HDD
Toshiba e-studio 3510c
Check that the cable that comes out of the back of the feeder is plugged in completely. If not, turn off the machine and unplug the copier before plugging the adf connector in, then turn machine back on.
If that is not the problem, the sensor flag or sensor may be out of place. Where the paper goes in, there should be a black plastic flag hanging down that the paper will move when you insert it, If you can see it and it seems to move properly, then the sensor may be out of place or the sensor/feed medchanism is out of place and it is a little tricky to explain here. The sensor is above the flag, but under a metal plate and you may mess it up worse by trying to take it apart.
Nov 19, 2011 | Toshiba E-STUDIO 211C Copier
Scanning Question
Right click on the document (right mouse button) and left click on "rename". type new name in.
Jan 26, 2010 | Toshiba COPIERS E-STUDIO 520 Copier
After switch on the toshiba e-studio coming uo
please do the following..
  • Open the ADF cover.
  • If shipping tape is present on the blue document feed-guide assembly, remove the tape.
  • Using the blue handle, lift the ADF rollers.
  • Remove the document.
  • Lower the ADF rollers.
  • Press the two tabs on the document feed-guide assembly to secure the assembly into the proper position.
  • Close the ADF cover.
  • Fax, scan, or copy again.
  • Jan 20, 2010 | Toshiba e-Studio 232 Black and White...
    Copies run through feeder distorted
    Document feeder Paper feed rollers should be cleaned with alcohol, blow out the document feed area with compressed air (computer duster), check feeder for bits of paper, post it notes, and signature flags. Clean glass, check for sticky areas on the glass.
    Hope this is of some help.
    Ed
    May 12, 2009 | Toshiba E-Studio 3511 Color Copier
    Paper jam on my toshiba 2060 model
    Exactly where in the machine does the paper jam??If it jams when you hit the print button, try cleaning the paper feed tires with WD40.spray it on a clean cloth, clean the feed and pickup tires thoroughly and make sure to get ALL of the WD40 off the tires before using the machine.If you take the paper cassette out and look with a flashight you should be able to identify the paper feed tires.
    Mar 24, 2009 | Toshiba 2060 Copier
    Can a scanned document be retrieved after the fact?
    anything you copy or scanned does not store in harddrive...it erase instantly after it sends it or copies it. it's a information security regulation...but if you e-mailed it it should be in a workstation cpu folder.. normally called SCAN folder.
    Dec 26, 2008 | Toshiba COPIERS E-STUDIO 520 Copier
    Pops up lime wire, curser won't work, extremely slow
    Try downloading Avast Free version. I have had great success removing things infected from LimeWire with this software. When you download and get it set up, it will ask if you want to set up a boot scan. Say yes. Let the system re-boot and run. if something pops up it will pop up a window with a siren on it. move everything to the chest. Do not delete anything as it may be a system file that you delete. Lime wire is a haven for viruses. I would suggest getting rid of it.
    Dec 02, 2008 | Toshiba Satellite M35X-S349 Notebook
    Change default tray for E-studio 520
    go to Control panel, select printers and faxes (windows XP),then select es520,right click properties, select Tab advanced,then you should click on printing defaults. then will open toshiba driver defaults,go to paper handling tab. THERE IS option called "destination" and there you can chose exit tray (inner,tray1,tray2...etc). After selection you must click apply and then ok. and that it. every time after that documents will be printed out to selected tray.
    Jul 25, 2008 | Toshiba COPIERS E-STUDIO 520 Copier
    Muratec F-520
    It could have something to do with the automatic document feeder. There could be something in there that is blocking the paper from feeding in there correctly. It could be the feed tires or the belt as well in the document feeder.
    It should be looked at by a technician in your area in case there are some parts that need to be replaced.
    Jun 26, 2008 | Muratec F360 Plain Paper Laser Fax
    130 people viewed this question
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    jasbo
    jasbo
    Branko Djurdjevic
    Branko Djurdjevic
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
