Question about Samsung RS2630SH Side by Side Refrigerator
Fridge tempertature the fridge temperature on front of fridge freezer keeps flashing at 2 and the fridge inside isnt cool ... what should i do to reset the temperature and at what temperature should the fridge be at ?
  • 1 more comment
  • htran Aug 08, 2008
    We had the same symptom, is it cause by the evaporator coils ice-up?
  • Anonymous Sep 09, 2008
    I HAVE A RS2630SH SIDE BY SIDE REFRIGERATOR , MY PROBLEM IS THAT THE FAN INSIDE THE REFRIGERATOR IS NOT WORKING. THAT FAN CIRCULATES THE COLD AIR INSIDE.
    COMPRESSOR IS WORKING, ANY SUGGESTIONS.
  • Anonymous Mar 25, 2014
    RS22FLMR refrigerator the fridge section temperature not cooling and is flashing 6 what do i doRS22FLMR refrigerator the fridge section temperature not cooling and is flashing 6 what do i do
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Posted on Sep 01, 2008
My frost free fridge freezer is working but flashing de on the front. I'd like to know what it means
Error codes are brand (and often model) specific. "de" likely indicates something in the defrost process, especially on G.E. Check for ice build-up in the freezer cooling coil. The control board would be suspect, but must be checked to confirm the precise fault.
Oct 20, 2014 | Refrigerators
Beko CDA751FW/1 mostly on all the time - fridge 4 degC, freezer -30degC
there is no thermostat in cda751fw/1. apparently the pcb controls fridge temperature. which pcb, the main one or the one behind the temp dial I dont know which.
Apr 11, 2012 | Refrigerators
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
May 17, 2009 | Samsung Refrigerators
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Whirpool Fridge
Hello Maxleilao,
Welcome,
You said, Both Freezer and Fridge compartments stopped keeping optimum temperature. Freezer compartment is working as a fridge, and fridge also not keeping the temperature as it should. Both temperature controls are on maximum (I actually tried many different combination's with no luck).
What is the model #.
How old is it?
If the fridge is only a couple of years old , try turning it off and then! unpluging it for 5 minute and then
restarting it.
What happened?
if nothing good then most likely it is this next task!
It should be on a sticker inside the door jam or close to it on the inside wall of the fridge.
If it is real small like a counter high fridge, the number may be on the rear.
If the fridge is full size fridge check in the rear to locate where the condenser is. (lt looks like a thin row of black tubes that the freon travels through).
If not and they are under the fridge behind a removable plastic grille in the front of the fridge.
If this is the case then remove the plastic grille to see if the rows of thin (black tubes) called a condenser is covered with one to two inches of dust and not visable yet due to the blanket of dust!
This makes the condenser (black tubes) hot and unable to cool.
Air is sucked in from the front and passes over these tubes and cools the freon.
That is making it hot and the fridge and freezer warm.
You will need a flash light,
The plastic grille comes off when you press down on the top and up on the bottom together. Like squeezing the grille with your fingers until it comes off in your hands.
Get a flashlight, and get down on the floor and look under the fridge at the condenser. If all you see is an inch or two deep of lint and dust, then you need to buy a refrigerator brush at the hardware store and clean the thick coating of dust off.The brush is one inch wide and round with a very long handle 36 inches. Do this very slowly and gently. Remember the freon is in these tubes so you don't want to bend them and get a leak.
I know this was a long explanation but if this is the case I just saved you a service call.
It will take some hours to get cool again if this did not cause any damage to the compressor!
Some times all night till it reaches the max. temperature.
If there is no condenser below, or this does not do the trick, you may need to replace the thermostat!
or have a low freon level.
Waiting for your response
Let me know!
Huuum
Please remember to leave a rating at the end!
Oct 08, 2008 | Whirlpool GD2SHGX Refrigerator
Bosch KGU32160 fridge freezer
The compressor behind the fridge should cycle on and off as the machine maintains temperature, but the evaporator fan inside the freezer will keep running, except when the fridge goes into defrost. If the noise is coming from the fan inside the freezer, there could be some ice on the frame of the fan and the blades are touching the ice. If the noise is coming from behind the fridge it could be the condensor fan motor. This fan is situated behind the fridge in front of or next to the compressor. It keeps the condensor cool by blowing air onto it. Check this fan. The blades could be touching the pipework or something.
Oct 31, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
1,602 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
