Question about Philips 15PF5120 15 in. LCD Television
Hello the problem with my tv is when are going to plug in ,this tv don't do nothing?please what can i do??? thank you.
    Genius:
  • 1,126 Answers
Remove the back and replace the power supply, or replace the bad electrolytic caps on the power supply and it will take care of your problem
Posted on Mar 24, 2011
  • 822 Answers
Sounds like power supply problem.......
cheers
Hello, I have a Samsung LN52B630 TV that quit working...noticeably after a confirmed lightning strike nearby.
Screen coming on when the main plug is removed is normal, that happens on most TV's...Are the spots that have no volts supposed to have voltage? there is a legend on the board to tell what voltages belong no what pin, check that
Oct 28, 2017 | Samsung Televison & Video
My Magnavox T.V won't allow me to watch actaul Tv
you will need to tuned every channel then save it to the memory. you can use the user manual of your tv for instructions. if you don't have user manual i'll try find from you, just give me the model of your tv.
Nov 03, 2012 | Televison & Video
I have a 55ex500 that the hdmi inputs do not work. It was tickled by lightning when it went out. Only one cable was connected at the time.None of the 4 inputs now work.There must be a replaceable hdmi...
Hello sorry If unit was subject to lightning.The only way would be to replace main board .But if you have not tried to reset tv.You can try to reset tv bu unpluging it for about 15 seconds .Then try that.Before you unplug unit.Unplug all inputs from tv .Once tv is pugged back in.Then plug in your inputs.Please let me know..Thanks
Sep 23, 2011 | Sony Kdl55ex500 Model 55ex500 Kdl55ex500...
How do you scan the channels on the PDH42L40? I need to go to a certain channel on the TV to get my Dish Network to work. It is not hooked directly into a box, it is on a secondary receiver. Please...
hello and good day to you!!!!
if you wish to scan your TV to go for a certain channels..
you need to reset auto scan on your TV...
this are the procedure on how to reset auto scan...
  1. Get your remote control..
  2. press the menu button on your remote
  3. go to the settings..
  4. try to find the auto search.
  5. after you find the auto search press enter to scan the channels.
Note: Please complete the 100% scan for better results..
Jul 12, 2011 | Televison & Video
I was watching tv and the tv turn off itself than no ligues no power and i try to turn on again and nothing happen what i should do?
Good day!
The problem of your TV is the power supply board.
Please follow this procedure to fix that problem:
  1. Remove the back cover of your TV.
  2. After that,look for the power supply board.
  3. Next,check the input voltage of the power supply using multimeter tester (range in AC).If the power supply don't have input voltage,replace the power cord.
  4. If the power supply board have input voltage,next is check the output voltage of power supply it should have 5vdc for the system board,12vdc for the sounds and 24vdc for the back light inverter.
  5. If you don't have output voltage of the power supply.Please check the fuse if busted and the power transistor if it is shorted,replace it with the same type,ratings and value.Also look for any leak/bulged on the top capacitor.
  6. After you done this steps and you found and replace the defective parts.Plug-in your TV and power it ON to test if it is OK.
The power supply looks like this:
If this solution will be help you to fix your problem,please don't forget to vote and rate my answer.Thank you for using FixYa and good luck.
May 08, 2011 | Vizio L37 Television
Hello, I have an Orion AC/DC 2 Way Power 9 inch combo with VHS player, and I can`t find the power cord. I haven`t been able to find what I need online and need to know what kind of cord I need, and where...
HELLO SOMEONE GAVE ME THIS TYPE OF TV BUT WITHOUT A REMOTE CONTROL AND I DONT HAVE ANY CLUE WHAT REMOTE CONTROL WORKS WITH THIS TV BUT IF YOU KNOW PLEASE MESSAGE ME TO dsaveny@yahoo.com please its important -thanks
Apr 10, 2011 | Orion Televison & Video
Hello,i just bought a old atari (6 switch top)from around 1980 or so. at a garage sale,the people said it worked.Brought it home plugged everything in till i got to the wire coming from the game console to...
Hello there, yes you need a simple adapter here and then can just use it with a regular coax (cable tv) cable, this video demonstrates it clearly for you:
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Oct 12, 2010 | Atari 2600 Console
My Hello Kitty tv won't come on, just a white line
frame colapse seek tv repair sho/ nothing you can do
Dec 10, 2008 | Spectra Logic Hello Kitty 13" TV
Philips 15PF5120 15 in. LCD Television Logo
134 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
